#611
Re: Delay Compensation bug in PT11 with AOS plug-ins (fixed in PT 11.2.1)
Curious how this fix is going for everyone... I've done a new cue with all tracks in auto-report and all seems good over here. HD Native.
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB HD Native PCIe card /// OWC Mercury Helios 3S PT 24.3.0 |
#612
Just updated. HDX 11.2.1 crashes every time I try and load the session I was working on in HDX 11.2 not 20 minutes ago.
Have to say, last couple of updates have been less and less stable here. Really hoping this one fixes the issue where ProTools fails to sync to incoming timecode if system delay is more than about 2000 samples, but I need it to just work first. Jules |
#613
I scored an entire feature with 11.1.3 without a video error. Is Avid f'ing with us??? |
#614
#615
OK, so working on a song over the weekend in PT11.2.1, everything working as expected and - happily - rock solid, I then route 3 acoustic guitar tracks to an Aux master and instantiate a Waves LinEQ followed by a Waves L1 limiter... WOW! massive latency caused by the LinEQ and not compensated for by PT so big timing issues (nearly 3000 samples of delay n the Aux).
I was hoping this issue had been fixed or am I missing something? Delay comp definitely ticked in the Options menu. all audio tracks, no VI's, no MIDI, 35 to 40 tracks, CPU usage absolutely negligible. Mac Pro 3.1 16gb ram SSD system 10.9.3 PT11.2.1 7200rpm audio drive |
#616
Bouncing VI tracks and importing them delay is still off. Plus Every time you bounce and import the delay is different.
It's still not working as it should - Again who is testing this do they even know normal session workflows. You HAVE to be to bounce out stems for clients from VI tracks. CAN THIS PLEASE GET FIXED - PROPERLY! |
#617
Can you expand the process you are using? |
#618
Was running 11.1.3 and generally all was fine. Updated to 11.2.1 and while other things were great, I couldn't successfully BTD. Down-dated back to 11.1.3 and things are OK again. Thank goodness...
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
#619
Every single bounce to disk when recording down VI's the timing shifts and floats around in time - like little fishes in the sea
#620
I was still getting bounce latency until I did that.
major PT11 delay compensation weirdness. | frozenintime | macOS | 18 | 02-18-2015 05:38 AM |
LE delay compensation plug ins | nossnevs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-14-2007 11:57 AM |
Plug-in Delay Compensation | Nard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 10-03-2006 05:18 PM |
Plug-In Delay Compensation | guitar131 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-31-2005 03:31 PM |
Plug In Delay Compensation | tj_davies | Pro Tools TDM Systems (Mac) | 7 | 09-29-2004 11:51 AM |
