advice on what to buy
ok, Im finally ready to move out of the mix world and into the realm of HD. I was hoping for some advice on what to buy (pt and cpu). my budget is about $7000 (for pt and cpu) I am less interested in processing power and more interested in variety of plug-ins. I need alot of options when it comes to plug-ins. Id like to be in the latest version of pro tools. Im asking here because I really dont know alot about these newer systems. any advice would be great.
Re: advice on what to buy
One rule of buying audio gear: never buy anything a month before AES
--Jeremy |
And $7k for PTHD and CPU = used HD1 (barely) which is pretty much useless IMO.
my last computer purchase was used dual 2.7 G5
i saved a lot i would not be afraid to buy a used HD rig especially if i could see it in action before purchase you may be able to hold on to your budget at least close anyway
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Um, have you looked at the Digidesign web site? A basic HD1 system (which is really just the card and the PT software) lists at $8000. That doesn't include an interface or a CPU.
To fit within your budget, you would need to save wherever you could and buy everything used and get a minimal system (HD1 with a 96 I/O). As others have suggested, this minimal of a setup has limited capabilities, so maybe you should state why you feel that you need HD as opposed to a Mix system or LE. You mention that you want lots of plug-ins and aren't interested in processing power. Well, you need processing power to run all those plugs. You might consider gettting a killer new Mac Pro and a Digi 003 if you don't need all the features of an HD rig, and then you will have plenty left over for plug-ins.
www.clifnorrell.com |
are'nt the tdm plug-ins much better quality than RTAS? with a 003 would the quality be limited ? I also need to be able to mix in 5.1 surround I dont think I can do this with ptle. I was told that an hd1 was 3 times the processing power of a mix plus system. if thats true I dont see how I would be limited. maybe with plug-ins..
does anyone know of a good source to find used systems other than ebay?
the For Sale section here on the DUC
some of the "gear brokers" will some times have a use rig or two
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Not sure about 5.1, so do some research. You can always mix for 5.1 by manually configuring busses and outputs, but it certainly makes it easier when you have 5.1 tracks already set up for you. Without 5.1 tracks and bussing, you might only be limited by the flexibilty of ease of surround panning. As far as an HD1 being 3 times as much processing power as a Mix Plus? I highly doubt it. I have a feeling that it is closer to about the same power, honestly, and HD1 could possibly even run less plugs than a MixPlus, depending on which ones and how many instances. HD1 might be about double the power of just the Mix card without the Plus. Again, search the DUC. People have posted extensive testing results on how many plugs can fit on each type of card and chip.
I'd go with a HD2 (process about $400 on ebay) Keep in mind that some plug-ins will only run on Accel. And what Jeremy said about AES, |
I could use some advice | Tebbes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 12-05-2011 12:35 AM |
Mac Pro help, advice.... | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-03-2008 07:37 AM |
Need Mix Advice! | vocalize | Pro Tools TDM Systems (Mac) | 5 | 11-13-2006 04:27 AM |
new and need advice | noisetree | Pro Tools M-Powered (Mac) | 2 | 11-12-2006 07:28 PM |
new and need advice | noisetree | Pro Tools TDM Systems (Mac) | 1 | 11-11-2006 10:08 PM |
