Old 01-08-2010, 12:51 AM
Meltdown Meltdown is offline
Default Busses Changing Levels When Reopening After Saving Mix
Why are the levels of my busses /auxes changing after I save a mix and reopen in in Protools?
I have a TDM Mix Plus System. When I mix I use busses.
Another strange thing that happenes is: Mix sounds fine, I Bounce To Disc and the mix is differrent when BTD file is played back, sounds
like the same thing thats happening when the buss/aux volumes change.
Alot of time has been wasted finishing up mixes only to have it changed after I reopen
Does anyone know what is happening and how I can stop this?
Old 01-09-2010, 01:20 PM
Default Re: Busses Changing Levels When Reopening After Saving Mix
Is there anybody...out there. Has anyone else ever had this problem?
Old 01-09-2010, 08:39 PM
Fullsound Recording Fullsound Recording is offline
start a support ticket i would guess.
www.fullsoundrecording.com
Seattle Wa
I voted at www.deardigi.com
Old 01-09-2010, 08:40 PM
Maybe try trashing the prefs and data bases
Seattle Wa
Old 01-10-2010, 01:14 AM
Hey Fullsound, thanks... I tried the trashing stuff and also tried creating a new user in XP which did not solve the problem. I have 2 similar systems and on the other Mix Plus system Im having the same buss changing level problems. I have both systems side by side and im trying to get them to stop, so I can get back to making music. Just now I was testing, I brought up a mix, it sounded ok. I then created a stereo aux(nothin else), As soon as I hit play again my drum sub/aux was super loud, and you can see the increase on the sub meter also. This is getting pretty frustrating here.
Old 01-10-2010, 06:06 AM
Gravyblue Gravyblue is offline
does this happen if you do the same thing, but with groups suspended?
Old 01-10-2010, 08:54 PM
Hey Gravyblue, I checked the suspend all group and gave it a try but no luck.
Old 01-10-2010, 11:43 PM
dbjp dbjp is offline
Did this suddenly happen on both systems or has it always been like that? If it's suddenly happened on both systems, I don't think it will be too hard to figure out what the culprit is (most likely something you installed, updates, etc.)
Old 01-11-2010, 12:33 PM
It started on one and then when I started setting up some buss compression Auxes for my mixes it started on the other. It doesnt happen on every session but every session pretty much has a similar layout/plugins etc.
I dont understand how an install/update can affect buss levels just by creating another buss. Am I using too many auxes? On one session I setup a virtual 8 stereo buss/AUX console and noticed that the volume changed ALOT depending on which buss/ aux i had it assigned to. WTF. I thought it might have been my inteface cables and even the interfaces -till i swapped everything out and it still did it.
Both are 6.4.1 tdm Mix plus on a P4 PC/Asus p4p800-E Deluxe-mb/2gb ram/a raptor 74 gb system drive,i have a separate sata drive for my PT sessions and I have Adat bridges and 888 24's
Old 01-11-2010, 03:06 PM
daveq daveq is offline
I use Mix plus, PT 6.4 on a Mac. I have had this level issue happen when running a session with the faders at +12 rather than +6. One of the CS updates was supposed to fix this, and it has helped, but I try and stick to +6 when I can just to be sure. :)
I've also seen the master fader level come out 6dB lower than it should in this situation?
daveq
Busses not recalled correctly when reopening sessions SpookyPirate Windows 32 08-22-2012 08:06 AM
Busses get deactivated when changing L/R output? mtung ICON & C|24 0 04-27-2009 05:13 AM
Changing busses causes image problems... acacia Pro Tools TDM Systems (Mac) 2 03-27-2009 04:10 PM
Problems with busses and levels in Protools 8? doubtful guest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-26-2009 10:47 PM
6.4.1cs2 Output levels still drop upon reopening Tim R. Pro Tools TDM Systems (Mac) 9 02-15-2005 05:21 AM
