Old 12-03-2002, 09:44 PM
clutch clutch is offline
Default Minimum memory issue
I have an ongoing issue and I want to know if I'm alone.
Some of my PT users insist on changing their memory allocations which is not a major issue until they change the minimum value.
The problem is - when I go to change back the minimum value to the factory default (by putting a 0 in the box) it instantly reverts to what the user set it at.
I can recreate this on all of my PT 5.1.1 stations running OS 9.2.2.
The only way I can get it to tell me what I assume is the ACTUAL minimum value is to put in something silly - like 100k and try to close the window. It will then say PT need at least 10,015k to run etc etc.
Is this figure the actual correct minimum value or a base system value?
Trash prefs etc doesn't make a difference.
any ideas?
He used to cut the grass...he was a very nice boy...
Old 12-04-2002, 12:12 AM
Boom Chic Boom Chic is offline
Default Re: Minimum memory issue
Are you entering "0" and then hitting " ENTER " in the "get info-memory" window?? That should do it.
Karen Basset
Boom Chic Studios
Los Angeles, CA 90048
karenbasset@hotmail.com
http://www.boomchic.com
Default Minimum Memory Setting saeblee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-07-2003 05:50 AM
minimum memory settings? vindaloo99 Digidesign Hardware & Software 3 04-12-2003 04:06 PM
Minimum and recommended Memory after expansion PlugInJunky Pro Tools TDM Systems (Mac) 3 08-23-2002 12:22 AM
minimum memory allocation for dae/PTLE dcurran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-04-2002 09:27 AM
never change minimum required memory ?? Chris Lambrechts Pro Tools TDM Systems (Mac) 7 09-05-2000 04:31 PM
