Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 09-12-2008, 09:37 AM
marisolmet marisolmet is offline
Default Please help Digi Support! Automation Control Window doesn't display completely
Hi, I'm a new user of Pro Tools M.Powered 7.4 and I'm having trouble trying to apply the automation on my session.
I've followed all the steps related to enabling tracks for automation and put them on the "write" mode. But the problem appears when I open on window/automation, it displays a small window that contains only the first part : "suspend, write enable.volume, pan, mute, plugin,send vol, send pan and send mute" that's it. It doesn't appear the play or stop button or any of the other controls that the PT Reference Guide talks about.
What can I be forgetting to do? Is there anything missing?
Thank you.
Old 09-14-2008, 03:40 AM
mradlauer1 mradlauer1 is offline
Default Re: Please help Digi Support! Automation Control Window doesn't display completely
The window your seeing is the Automation options for that track...Anything RED is enabled...
IF you are in one of the write modes, and you have the option enabled, you can play your track, then move the fader, panner or whatever it is you want to automate...
If you want to draw automation, you will need to be on the edit screen...change your track view from "waveform" to "volume", "pan" or whatever it is you want to automate...then you can use the edit tools to draw in your automation...
Hope this helps.
Old 09-14-2008, 07:16 AM
Stig Eliassen's Avatar
Several automation features are Pro Tools HD only, I'm afraid.
Universe Window completely gray Armando Pro Tools TDM Systems (Mac) 2 10-19-2012 03:50 PM
Universe window completely gray Armando Pro Tools TDM Systems (Mac) 0 06-01-2012 02:30 PM
Does Digi official support more than on display monitor?? Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-14-2009 08:27 AM
Does Control |24 support Digi 002 or not? coryc ICON & C|24 1 10-12-2003 03:53 PM
Edit Window Display not completely visible Douglas Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-26-2002 10:14 AM
