Old 10-10-2006, 11:55 PM
Tweakhead Tweakhead is offline
Default PT7.2cs1 Memory Leak?
I am running a pretty complex session with thousands and thousands of regions and edits. Size is about 4Mb for the Pro Tools session document.
The session gets slower and slower after several hours especially when flipping between playlists, and quickly clicking in the Undo History to undo/redo edits to AB different versions of edits on playlists.
If I reboot the entire computer it then behaves quickly again but after several hours becomes unbearably slow once again.
Is this a symptom of a memory leak?
Anyone else seeing this behavior?
Old 10-11-2006, 04:27 AM
Brandonx1 Brandonx1 is offline
Default Re: PT7.2cs1 Memory Leak?
Hi Tweakhead,
I'm having a similar issue with pt 7.2 (and release) on XP. Mixing a movie with 6 reels lots of tracks and edits. Just coping fill audio takes about 30 seconds. Maybe it's the same problem?
Brandon
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 10-11-2006, 05:09 AM
manichouse manichouse is offline
I had this happen yesterday on a rather large 5.1 mix for a 1hr doc (on Win XP too). I was riding an automation pass for the last 10 seconds of the program and I got this "end of stream" error, a ProTools crash, and the session file was reduced to 1k and would not open again. Dangerous.
Martin Trum
Old 10-11-2006, 12:08 PM
Thanks for the info guys. I'm sorry (but relieved in a way) that it's happening to you too.
Any input from Digi on this fairly serious matter?
Old 10-14-2006, 01:33 AM
After having done further tests on this problem I started off the day doing a snapshot in Process Viewer of how much memory Pro Tools was using immediately after a reboot and opening my session. After several hours of working I noticed the slowdown happening, and did another snapshot in Process Viewer. The memory consumption (both real and virtual) had increased by about 50% even though my session was actually being slimmed down in the editing process.
After a reboot it reduced once again to the lower level.
I particularly notice the slowdown when quickly clicking in the undo window to A/B playlist switches.
Memory leak going 11.01>10.3.6 DetroitT Pro Tools 11 0 07-18-2013 03:42 AM
Memory leak/leap simonchase Pro Tools TDM Systems (Mac) 1 05-05-2011 07:30 AM
Memory Leak in 7.3? BlindDog Pro Tools M-Powered (Win) 2 01-15-2007 08:21 PM
Memory leak in PT7cs3? UnkleMik Pro Tools TDM Systems (Win) 1 02-03-2006 12:53 AM
Protools Memory Leak???!!! Agentemo1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-08-2005 05:39 PM
