Remap midi controllers?
I am trying to find a way to remap MIDI cc7 to cc11 -- on the fly.
The situation: Some (many) VIs respond to cc11 (expression) independent of master volume. This is correct. There was a thread over at Northernsounds that I was involved with, and the "composer types" who use some VIs really have no respect for bus level and good engineering techniques... http://www.northernsounds.com/forum/...-output-levels but that's besides the point... my issue is Kontakt and some other VIs do not respond to cc11 unless you manually map each patch -- and I really don't want to go back and forth between setting my volume pedal to cc1 vs. cc7 depending on the sound I am playing -- ADDITIONALLY, in protools, navigating from note/velocity/volume in the edit page is as simple as "control-command-right or left arrow" -- but to get to cc11, it's a hike... So what do you guys do here? DO YOU USE cc11? How do you differentiate between cc7 and cc11? How do you effortlessly edit cc1 without navigating there? What am I missing? In logic, the "transformer?" tool could solve some of this? But I am using ProToolsHD. What's the better workflow for expression (midi volume) when you want to constrain the max output level of the plug to a normal 0vu = +4 dBu = -18 dBFS ?? Spectrasonics wants me to use cc11 for expression. But in Kontakt, I can't without remapping EVERY SINGLE patch. What are you guys doing? Thx J
--Jeremy |
Re: Remap midi controllers?
I haven't tried this product but it looks powerful.
"...Another way to use the product is for MIDI control remapping and transform: assign an input parameter a given MIDI CC, and assign the associated output parameter to another MIDI CC with different response curve parameters: the plug-in will remap the controller to the new CC and channel with a new response curve." http://www.bluecataudio.com/Products...RemoteControl/ RTAS demo is available. Busch. |
http://dl.dropbox.com/u/427719/PT-Controllers.pdf It's available then with ctrl/cmd/arrow.
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
any new solutions? I have the same issue in PT w/ Kontakt, Omnisphere, Wavestation, etc.
Actually, the Korg Wavestation VI doesn't seem to respond to volume (7) or expression (11) so i'm trying to figure out a way to control the PT fader for the instrument channel w/ my expression pedal. Any ideas? |
Midi Predifined options in Peripherals\Midi Controllers menu | RuffinMedia | macOS | 3 | 03-04-2015 04:54 PM |
possible to remap transport key on Artist Control? | studioj11 | Artist Series | 1 | 11-15-2013 11:28 AM |
Waves Gold bundle can't remap DSP | amptbuddy | Pro Tools TDM Systems (Mac) | 4 | 10-24-2006 07:26 PM |
Waves Gold bundle can't remap DSP | amptbuddy | Pro Tools TDM Systems (Mac) | 0 | 10-22-2006 12:24 PM |
How do you remap spotlight key command? | abbyin3d | Pro Tools TDM Systems (Mac) | 3 | 11-12-2005 09:59 AM |
