Effects Sends Help!!!
Hello,
I posted a similar question to this not long ago. The problem is when sending to outboard effects units. Quite often the sound doesn't make it to the speakers. Now, I know the signal is leaving the computer, making it to the outboard effects unit and making it back into the computer as all the relevent meters are lighting up. I've found that the problem occurs most often when you solo a channel and then unsolo it. The said channel that is being sent to the outboard works before the soloing (of any channel) but disappears when I return to the full mix. Now, is this problem common to all versions of protools LE or just 6.4?? Now the latest problem I'm having is when bouncing to a wave file (during the actual process of bouncing down), the channel that is being sent to the outboard effects can be heard in the mix but when I listen to the actual wave file, that channel is no longer in the mix!! Anyone have an answer?? I'm desperate here as I have some great outboard gear that is nearly useless because of this!!! I'm running Protools 6.4 LE Digi 001 Pentium IV 3.0ghz 512mb ram Thats about all I can remember for now. An answer would be great!! If you need more info, please reply and I will get you all the info I can - WOW! What a long winded post!! Thanks!! Kubba |
Re: Effects Sends Help!!!
a couple things to check..
make sure your aux channel that you are using for the outboard gear is outputting to 1-2 like all the other channels. As far as soloing ..if you solo say a guitar channel that has some outboard effect applied through an aux send..you must also solo the aux channel to hear the effect in solo. I generally put all my AUX channel effects in solo exclude mode. I believe it is CNTRL click on the solo button of the Aux channel and it should go grey. then when you solo a channel the aux channels are not muted. hope this helps some bb as an edit are you using outboard gear thru an aux chanel send or as a channel insert?
Macbook Pro Intel dual 2.4 OSX 10.7.5 Lion PT 9.0.6 Mbox Mini / 003R MAC G5 PPC OSX 10.4.9 / PT 7.3 HD2 - I/O 192 /Control 24 DELL Dual Core, MBOX/003R PT 8 WIN XP |
Bryan,
Thanks for the reply. I'm not setting up an AUX track and then sending to that. I've inserted the outboard directly into the original track. So I'm inserting the outboard gear in the "Insert" section of the channel. Does this make sense?? Anyway, thanks for trying. Maybe I didn't explain it well enough? |
That makes perfect sense in an analog world, but PT (or any DAW) needs a different approach. I suggest you send out to your external processor and record the new signal to its own audio track. This way, you can use the original to help align the processed version(and you will need to align it). Once that is done, simply shut off the original track voice. You can always redo if you need to.
Sends default to -inf preference...resetting all sends to 0 | Nathan W. | Post - Surround - Video | 3 | 07-15-2011 12:10 PM |
effects and aux sends | bigmarkus | Tips & Tricks | 5 | 01-03-2006 06:42 AM |
Aux and Sends question- Effects | rightsidefalls | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-27-2004 08:24 PM |
outboard reverb and effects using the aux sends and inputs | A Chadwick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-22-2002 01:42 PM |
Sends, Aux and Effects | pmh3r | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-16-2001 11:03 AM |
