Old 12-20-2020, 08:50 AM
Benny Mouthon's Avatar
Benny Mouthon Benny Mouthon is offline
Default AUDIO SIGNAL INDICATOR on Folder track missing from CONTROL app / SPLIT MIX window
I'm in audio post and have a bunch of different AUX reverbs in a basic folder track, which is often closed.
Sometimes I need to quickly check if there's some reverb present, the ASI box in the MIX window (below the MUTE button, see pix) is great, but it's not present in the CONTROL app on my iPad (sitting on 2x S1's).
Also, in the MIX window, it's often hidden by plugins, or not at the right place (I'm usually working with many tracks and need to scroll to this folder to see what the story is, but the iPad is set to always show my submasters and reverbs).
Unfortunately, the Universe bar in the iPad app also doesn't show signal when the folder is closed, but works fine when it's open.
Looking forward to this in a future EuCon/CONTROL update !!
Speaking of the MIX window, Excel allows me to split the spreadsheet to, for example, always show the top section, regardless of what is scrolling in the bottom one.
Would be nice to be able to split the MIX window in Left/Right and select all my submasters in the right section+"lock" them (unscrollable), keeping the left one scrollable as usual.
Thanks,
Benny.
Mixing Window, AutoMatch Indicator, can't change track volume.... cesarjperez Pro Tools 12 6 08-23-2023 09:39 AM
Another Folder Track bug: Solo cleared when folding track in Mix window XJENSEN Pro Tools 2020 11 04-11-2020 04:06 AM
Clip indicator with low signal spartanhooah VENUE Live Sound Systems 2 03-22-2012 09:36 PM
audio track missing pan control??? davidp158 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-01-2002 03:02 PM
Track Arm Window missing ... Samhein Pro Tools TDM Systems (Mac) 0 06-01-2001 03:46 AM
