Old 02-11-2020, 04:55 AM
stargazer stargazer is offline
Default HD OMNI stand-alone without PT running
Is it possible to route audio from the analog inputs to the outputs without Pro Tools running?
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 02-11-2020, 07:37 AM
creativecontrol's Avatar
Default Re: HD OMNI stand-alone without PT running
Yes indeed. That's why the OMNI has an integrated mixer. As shown below (pulled from the HD Omni Guide).
You can find more details in the guide here:
http://akmedia.digidesign.com/suppor..._v90_69707.pdf
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-11-2020, 08:17 AM
Thanks a lot, Jeff!
Old 02-11-2020, 12:03 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
One of my favorite things about the Omni!
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 02-12-2020, 04:13 AM
Is it possible to access the mixer without PT running, too?
Old 02-12-2020, 06:09 AM
K Roche's Avatar
K Roche K Roche is offline
To clarify the HD Omni guide as shown is a bit confusing it states using it to pass audio from CD player to monitors (which one would assume is audio in straight through to audio out) ??? BUT because in the lightbulb "hint" just below the Hardware Mixer Tab states using it as a stand alone "converter" not wether or not it will pass audio straight through ?
Here is my issue I ended up with two OMNI's. (So I will designate them A (main) and B (standalone) BUT unfortunately PT will not allow me to connect the via digilink expansion port . Like other AVID I/O devices, and have it show as a second OMNI or I/O
So what I would like to do is to be able to use it (B) as a stand alone mic pre to add two more mic inputs and outputs to my system, Use Audio 1-2 (mic pres) on it (B) and then route via line out 1/4 it into analog 3-4 line in of my main OMNI (A) running PT... IS this possible ? If I set it up as per the shown mixer setup ? I am assuming I would have to first digilink it (B) to my computer (as if were the main OMNI) and set this up then switch the digilink back to (A) And use it "standalone" from it's mon outs on (B) to go into the 3-4 Audio line in's on my (A) OMNI ?
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 02-12-2020, 06:21 AM
JFreak's Avatar
JFreak JFreak is offline
Theoretically yes, but why would you have two as only one ÓMNI can be preent in DigiLink chain when you run PT... what did I miss here?
Janne
Old 02-12-2020, 01:40 PM
Brandonx1 Brandonx1 is offline
And it sample rate converts the SPdif optical port. Amazing.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 02-12-2020, 07:15 PM
Ryan Young's Avatar
Yes, run "AvidAudioServerLauncher" which launches "AvidAudioServer". You get the Hardware Setup window without Pro Tools being open.
Applications > Avid > AvidAudioServer >
File Type: jpg Screen Shot 2020-02-12 at 7.14.30 PM.jpg (37.6 KB, 0 views)
-Ryan Young
Additional Systems
Old 02-12-2020, 08:17 PM
nst7 nst7 is offline
I think you have the basic idea. As you may have realized, in standalone mode, whatever you use for outputs will function as monitor outs, rather than typical line outs. So your signal will be affected by the volume control. It's been a long time since I tried something like this, but you may want to also experiment with using the Spidf digital outs instead of analog outs. You would then go into the Spdif input of your main Omni. For some reason I remember this actually working better, but I don't remember why.
Just bought an HD Omni. Does Avid offer free support to get me up and running? rcd Pro Tools 10 7 05-08-2017 03:58 PM
Omni vs HD 8x8x8 io and Omni Pre's Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 13 03-27-2013 01:00 AM
Dual Boot 10.6 running 8HD & 10.7 running 10HD STL Audio macOS 3 04-14-2012 05:38 AM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
