Old 10-03-2011, 12:19 PM
Imran5000 Imran5000 is offline
Default MBOX 3 Not Working - Blue Flashing Power Light
Hello I just bought the MBOX 3 to use with Reaper, followed all the instructions and just get a flashing blue LED with Pro Tools LE saying 'please connect your hardware' and Reaper also getting an ASIO driver error.
I am using a Quadcore with XP Service Pack 2.
I downloaded the Mbox Drivers v1.0.19 but that says 'This version of windows is not supported'.
Many thanks in advance
Old 10-03-2011, 12:27 PM
blackdognove blackdognove is offline
Default Re: MBOX 3 Not Working - Blue Flashing Power Light
try windows 7
Old 10-03-2011, 01:15 PM
That would explain it
Cheers for the quick reply!
Old 10-04-2011, 02:44 PM
Before I upgrade to Windows 7 I'd like to ask a quick question - is the flashing blue power light indicative of using the wrong OS or is there a problem with the power i.e. the MBOX cannot draw enough from my USB port/ something internally wrong with the MBOX. Someone on the net did say that their older Macbook couldn't provide the juice - I'm using a two year old Quadcore so I'd assume that would work ok.
I don't want to go through the major upheaval of a new OS with all the software re-installs to find there's still a problem.
Thanks again
Old 10-04-2011, 04:06 PM
Pinball Wizard Pinball Wizard is offline
Imran5000: Usually a flashing blue light is an indication of a clock problem but until you get the drivers running properly you can't be sure.
I note that you are on service pack 2. I have successfully run a Mixbox 3 & a Mixbox 3 Pro on Windows XP with service pack 3. The upgrade to SP3 is free but be prepared----it does take quite a while & you will probably find that there are quite a large number of updates to do after you install SP 3.
IHTH
Main Workstation: Pro Tools 2023.12.1, Windows 11, HP Z4 Xeon 8 core W2145, 64 GB DDR4, Omni, Artist Mix, Sync X, Eleven R(2 of them), UAD 2 PCIe card
Old 10-05-2011, 03:43 PM
Thanks for that Pinball Wizard. To be honest I returned it and swapped it for an RME Babyface. It's a shame because I've heard soundwise the MBOX 3 is slightly better - in terms of functionality/ looks etc it's way better so I wish I had a Windows 7 system up and running.
I do think it's a bit of an oversight not to have it run on XP though, there must be a few sales lost for people with slightly older set ups.
Old 12-05-2011, 08:35 PM
sunmedia sunmedia is offline
Hi...I Have This Problem....Do You Know Fix This?
Old 01-23-2012, 08:03 PM
d347hboy d347hboy is offline
I also have the blue light flashing each time I close/open the MacBook with Pro Tools on, but restart of the system solves the problem (not standard system restart, complete system OFF then ON again), I hope that helps to some
Flashing Blue Power Light (Mbox 3rd generation) ReenFamily 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-04-2014 02:15 PM
Mbox Pro Blue flashing light. New to Pro Tools EdwardxP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-29-2013 04:23 PM
Mbox 2Pro Flashing Power Light appleaudiond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-31-2012 05:11 PM
MBOX 3 Not Working Flashing Power Light Imran5000 General Discussion 1 10-03-2011 12:22 PM
MBox Power light flashing! ym2149 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2010 12:40 PM
