Command 8 & Mbox (does it work)?
i'm just wondering if an Mbox would it work with a C8?
i don't see why not, just wondering if there are any known issues etc.... i'll be using it for Mixing/DVD Authoring/Post (Avid Express Pro) most of the time with the once in a while artist etc.... (no drums) so i was just wondering if the 002R is just overkill for this or the Latency is more prominent in the Mbox than in the 002R. i'm thinking of buying Logic as well plus a Motu or RME for Surround since LE won't do Surround just trying to save some $$$ and have the best of both worlds at the same time. what you guys think? any recommendations? thanks for your help regards, CJ |
Re: Command 8 & Mbox (does it work)?
ANYONE ????????????????,
Works fine so far. Just hooked up my mbox with the C8 three days ago. So far, no problems at all. Go for it.
thanks Blinks
anyone have a comment about the integration of Logic into this i really need to know so i can buy the whole package although i'm wondering into setting up a Bose surround system for Logic & PT with an SPL or Big Knob or something Stereo = PT Surround = Logic what you guys think? thanks for your help regards, CJ |
Hey Blinks:
I have the Mbox and Command 8. I can't get the thing to record. Could you explain the setup, cabling etc necessary to make this work? BillyL |
Can MBox 2 and the Command 8 work together? | DeNiro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-30-2006 03:59 PM |
Does Command 8 work with Mbox? | Chewits | ProControl, Control|24, Command|8 | 1 | 07-14-2006 03:05 PM |
Does the Command 8 work with an Mbox? | razorballs | ProControl, Control|24, Command|8 | 2 | 08-29-2005 02:39 PM |
Mbox and Command 8 (Will it work)? | OmniMedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-08-2004 08:19 AM |
Mbox and Command 8 (Will it work)? | OmniMedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-08-2004 07:45 AM |
