Anyone switch from Serial Midi to USB Midi ??
did anyone make the switch from Serial Midi to USB Midi?
Is it worth it or should i stick with Serial Midi (Stealth Port)? If it is worth the switch... what does everyone recommend ? i want a easy to use, plug and play, usb midi rack mounted unit that works easily with pro tools.... im thinking of geting the opcode MIDIport 96 http://www.opcode.com/products/midiport96/ any thoughts ? Thanks In Advance |
Re: Anyone switch from Serial Midi to USB Midi ??
If you are considering going USB, why not wait for the Digidesign MIDI I/O? It will support Time-Stamping in a future version of Pro Tools and will therefore offer tighter MIDI timing than any other MIDI interface when used with Pro Tools.
Yeah, I switched about 2-3 years ago (one of the early adopters). There were a couple of issues with the first drivers, but it's pretty stable on a Mac now (don't know about PCs).
Like lagasus, I would also suggest holding out for another month or so for Digi's DTS interface if you mainly use PT. Otherwise, Logic has AMT and their own interface as do MOTU and Steinberg. BTW, there is a good article this month in Keyboard Magazine about Midi Time Stamping technologies. Although not particularly geeky, it does provide a good overview. So where the heck is the Midi Manufacturers' Association when you need them to corral all these guys for a SINGLE standard?
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
serial midi on G4 | ngareau | MIDI | 1 | 11-23-2003 04:47 PM |
Serial midi under 6.1, please help. | Dopamine | Pro Tools TDM Systems (Mac) | 4 | 09-16-2003 08:00 AM |
serial midi pt6 | Laurence w schuberth | Pro Tools TDM Systems (Mac) | 6 | 04-03-2003 10:33 AM |
Forced to switch from Serial Midi to USB Midi :( | Gnosis | Pro Tools TDM Systems (Mac) | 2 | 05-27-2002 02:12 PM |
Midi - USB or Serial? | fasttraxx | Tips & Tricks | 5 | 12-28-2000 12:06 AM |
