Old 08-10-2001, 10:27 AM
nobby nobby is offline
Default Running out of CPU power
Agghhhh!!!
Any more than about six plug-ins and I begin to run out of CPU power. My current setting is allocated 85% of the CPU power to Pro Tools. Is there any way to be able to use more plugins simultaneously. After all 24 tracks, add a few compressors, a gate and a reverb and the whole thing begins to cease up. It seems a bit limited! Any help greatly recieved.
thanks.
Old 08-10-2001, 10:30 AM
s.d. finley s.d. finley is offline
Default Re: Running out of CPU power
What is your system?
Some plugs are more cpu intensives than others. You could use mono reverb instead of stereo too.
sdf
sdf
sugarhillstudios.com
Old 08-10-2001, 11:14 AM
andyo andyo is offline
Try this: Destructively effect (Audiosuite) each track using "save as" as you go so that you can revert to old session if you ending changing your mind about reverb, comp, whatever. Also, use Aux sends for multiple occurences of one effect.
Andy O.
Old 08-10-2001, 11:32 AM
Zeus Zeus is offline
Using multiple playlists is also a solution to be considered when applying Audiosuite fx. Duplicate the playlist (or track if you prefer to call it that) to be effected and then Audiosuite.
Using save as... is a little bad if you make lots of edits and everything and then decide you don't like some audiosuited stuff. Of course the processing is in any case non-destructive but dragging and syncing the original files into their correct places can be a mess...
Z
Old 08-10-2001, 02:30 PM
WestPhillySoulzition WestPhillySoulzition is offline
I wouldnt use mono reverbs. sounds like ********
especially Dverb. stereo reverb on snare is an absolute necesity. feed mono snare to stereo
www.Subglo.com
Old 08-10-2001, 02:56 PM
lwilliam lwilliam is offline
We still don't know your system config...a G3/266 won't get very many plugins, for instance. Even my G4/400 doesn't get all that many on a 24-track 24-bit mix.
Just a bit OT....Actually, I've found that using mono reverb on some tracks really helps clean them up and give each instrument it's own space with better definition in a dense track. IMHO, using stereo reverb on everything is as messy as using all stereo sounds: it ends up as WIDE MONO.
However, I always use a stereo reverb on the snare [img]images/icons/smile.gif[/img]!
Using SOME reverbs in mono will definitely save you some CPU power. Also, try using a short or medium delay instead of reverb, it also takes a little less CPU power.
Use Audiosuite a LOT...
Larry
PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins...
Old 08-10-2001, 11:48 PM
Wow, I check back after one day and I have all these replies. You guys are fantastic!
I have one of the first Blue and white G3's, @300MHz. Obiously this is going to affect things. It looks like I'm going to have to be more sparing with the ffects I use.
I use the Aux method for reverbs and certain delays seem to work.
It would be nice not to have to process individual effects with audiosuite, it makes mixing such a chore. Process, mix, process, undo, mix, process etc. Oh well until I can afford the TDM system!!!
Out of interest does anyone know if Mix Farms work with 001
Many thanks
Old 08-11-2001, 01:10 PM
No, no TDM hardware works with the Digi001. But if you feel cheated, you anyway can run PT LE on the Mix system when you've upgraded into it! LOL
[img]images/icons/grin.gif[/img]
Z
running out of cpu power??? amoretam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 10-26-2010 11:58 AM
Running out of CPU Power Tip Here kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-08-2008 08:43 PM
Running out of CPU Power npratt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-20-2004 04:04 PM
running out of cpu power Jumpman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-06-2004 06:07 AM
Running out of CPU power w/ 2.6 ghz 1GB of RAM?!?! 72reissue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 06-29-2004 04:56 PM
