Old 06-30-2017, 08:23 AM
SWBoatman25 SWBoatman25 is offline
Default How do I automate an EQ sweep?
Hello, for instance.
I have a synth part in a song and I put EQ on it and add a bell curve of +3 or +6db and have it sweep from high to low because it sounds cool in playback when I manually sweep it.
My question: How do I record or automate that sweep so its permanent in the song?
All I can do is manually sweep in playback.
Thank you!
Old 06-30-2017, 08:26 AM
Drew Mazurek's Avatar
Default Re: How do I automate an EQ sweep?
Search the manual for Touch mode.
www.drewmazurek.com
Old 06-30-2017, 08:29 AM
priorytools priorytools is offline
Thank you!
Pro Tools Reference Guide Page 1066.
But I would suggest reading that whole chapter starting on page 1051.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools HD 12.8.3 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V3.6 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 06-30-2017, 12:01 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Thank you!
With virtually all AAX plugins you can assign just about any parameter to an automation lane. Refer to the manual on how to add a parameter to an automation lane. Once you've done that, then you can either record the sweep as you playback the track and manipulate the sweep, or draw it in manually. Good luck!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2018.12
Focusrite Scarlett 8i6
Old 06-30-2017, 04:16 PM
youtube.com is your friend.....
Old 06-30-2017, 04:29 PM
Bottom line, RTFM.
www.drewmazurek.com
EP-11S & GCP Partial 'Sweep'? EvilPhish Eleven Rack 0 10-13-2013 12:58 PM
Synth: creating a sweep sound/causing instruments to sweep promusix Pro Tools M-Powered (Win) 0 03-06-2011 03:51 PM
192#3 output lights sweep PTPerson Pro Tools TDM Systems (Mac) 7 01-20-2011 12:02 PM
Which plugin for Filter Sweep DaveSB Pro Tools TDM Systems (Mac) 2 11-03-2006 07:25 PM
Filter Sweep TDMS JLEpperson Tips & Tricks 1 10-31-2000 12:05 AM
