Old 03-02-2013, 11:23 AM
Dr. October Dr. October is offline
Default what version of pt le?
i apologize in advance for what may be a obvious question. i've got an mbox 2 and a macbook pro running OSX 10.8.2. what version of protools le should i be running? obviously the latest possible would be the obvious choice, but given it's an older generation mbox im just not sure if that would require an older version of le.
any advice is appreciated, thanx!
Old 03-02-2013, 11:45 AM
albee1952 albee1952 is online now
Default Re: what version of pt le?
I don't think any version of LE will work. I think you need 10.3.3(but it should work with an Mbox 2).
Old 03-03-2013, 03:24 PM
YYR123's Avatar
YYR123 YYR123 is offline
Yes he is right 10 will work just fine
Daniel
Old 03-03-2013, 05:19 PM
My first reply was short but you may want/need a little more info. Since PT9 rolled out, there is no more "LE". Also, be aware that your Mbox 2 will likely NOT work with PT11(which doesn't mean you can't continue with 10 until you decide to change interfaces). One great thing that happened with the release of 9(and 10) is; you are no longer tied to Digidesign/Avid hardware(so your next interface could be from RME, MOTU, Focusrite, etc...anything with a working ASIO driver(or Core Audio driver for Mac). I run 10HD software with my 003 and it works great(assuming a compatible computer)
Old 03-03-2013, 07:55 PM
Cawbaby Cawbaby is offline
Thumbs up Re: what version of pt le?
thanks for the responses guys, they answered my question and much much more
Dr. Caw Recording
www.drcaw.com
Pro Tools requires version 9.0.6 or later, but CFnd provides version 9.0.0 Danishan90 macOS 10 02-10-2014 03:11 AM
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but Patrick H macOS 3 11-20-2012 02:46 PM
HELP! PT10 Opening new version session in older version Claudiu Pro Tools 10 6 11-04-2012 03:32 PM
Incompatible library version: CFnd provides version 7.2.0 heshion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-24-2009 03:42 PM
version 6.x projects in version 7 won't load banm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-01-2006 09:15 AM
