Old 03-03-2013, 03:19 AM
Ben Jenssen's Avatar
Default Re: Balanced or Unbalanced? Does it matter?
Just for the record, balanced cables in unbalanced in-/outputs will not make a difference. The gear must be balanced. It won't hurt either.
My take on it; Use it whenever you can. It will protect against noise, hum, interference.
Old 03-03-2013, 05:53 AM
panamajack's Avatar
panamajack panamajack is offline
Originally Posted by tommytime555 View Post
Wow -- So I've been going out of the "SEND" 1/4" to the 002.... Am I gonna notice a massive difference by going XLR to TRS (I/O Out)?
The Focusrite ISA One has both unbalanced and balanced connections. The unbalanced connections on the front permit a TS "instrument in" to pass-through to an amp. For recording a guitar, bass or keyboard, you could use unbalanced cable to your 002 from the front panel "TS" output, but it is typically used so the artist can monitor their playing with zero latency, or so the engineer can mic up a cabinet at the same time as recording a dry signal. The right and left "Cue Mix" inputs are TRS, and permit a zero latency foldback.
The connections on the rear are balanced, and permit TRS ins and outs for several scenarios. Depending on whether you have selected "mic," "line" or "instr," anything connected will come out of both the "main output" and the insert "send." The main output is balanced XLR, the insert send is balanced TRS.
For "instrument" output, the "DI Output" is XLR and carries only the unbalanced input to the front 1/4" TS connnection, regardless of whether "mic," "line," or "inst" is selected on the front panel. This allows you to simultaneously record whatever is plugged into the unbalanced TS on the front panel independent of what is connected to either the TRS "line in" or XLR "mic in."
With cable runs of less then ten feet, you most likely can use either, but you should use the correct cable for whatever connection you pick! TRS and XLR balanced cables have better isolation from EMI and RFI.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 03-03-2013, 09:38 AM
EGS's Avatar
EGS EGS is offline
I'm probably way over thinking things here but -- when connecting a preamp to my 002, should I be using a balanced cable?
XLR to 1/4" is what I'm about to purchase but I'm not totally understanding the balanced vs. unbalanced importance.
Thanks!
T
Here's some info on the topic: http://www.rane.com/note110.html
Desktop: PT 2019.6 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook 4730s / i7-2630 / 8GB / U-PHORIA UMC1820
Info/Services link
Old 03-03-2013, 05:50 PM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
Default Balanced or Unbalanced? Does it matter?
This is a classic and excellent tech note that should be required reading by those entering the field.
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Unbalanced/Balanced?????? kmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-05-2012 05:19 PM
Balanced and Unbalanced Fishman1 General Discussion 2 09-25-2005 11:27 AM
Balanced / Unbalanced pipesurfa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-26-2004 01:44 PM
balanced to unbalanced oreo1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-13-2004 07:43 AM
Balanced or Unbalanced Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-12-2004 05:38 PM
