Old 03-02-2013, 09:39 AM
tommytime555 tommytime555 is offline
Unhappy Balanced or Unbalanced? Does it matter?
I'm probably way over thinking things here but -- when connecting a preamp to my 002, should I be using a balanced cable?
XLR to 1/4" is what I'm about to purchase but I'm not totally understanding the balanced vs. unbalanced importance.
Thanks!
T
Old 03-02-2013, 09:59 AM
sunburst79 sunburst79 is offline
Default Re: Balanced or Unbalanced? Does it matter?
Thanks!
T
Absolutely use balanced cable.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-02-2013, 10:01 AM
nst7 nst7 is offline
You want XLR to 1/4 TRS, specifically.
The 1/4 TRS has an extra ring on the shaft, vs. an unbalanced guitar cable.
Old 03-02-2013, 11:35 AM
Wow -- So I've been going out of the "SEND" 1/4" to the 002.... Am I gonna notice a massive difference by going XLR to TRS (I/O Out)?
Back of the ISA-ONE: http://www.music2home.com/images/pro...a_one_back.jpg
T
Old 03-02-2013, 11:47 AM
You likely won't notice any difference, UNLESS you WERE using unbalanced hookups and you were hearing noise in the signal. Balanced lines are much better at rejecting noise(hum, EMI, RF interference). Anytime you CAN use balanced connections, I would
Old 03-02-2013, 01:58 PM
So you're thinking it will sound different because I'll be using a balanced cable or because I'll no longer be going out of the "SEND" output on the preamp? I realize now that I should have been going out of the MAIN O/P and not the "SEND".
Thanks again! So appreciated.
T
Old 03-02-2013, 02:11 PM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
Default Balanced or Unbalanced? Does it matter?
It depends in parts on the circuit topology of the particular units you're trying to interconnect.
For exemple, is the main out passing thru a somewhat slow output driver & balancing transformer that is heavily coloured or is it a very clean, fast & accurate transformerless design.
Also, are you running 3 feet of cable or 30... Or 300!
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Old 03-02-2013, 02:27 PM
EGS's Avatar
EGS EGS is offline
+1 if at all possible. Balanced = pro = best. Google as to why.
Desktop: PT 2019.6 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook 4730s / i7-2630 / 8GB / U-PHORIA UMC1820
Info/Services link
Old 03-02-2013, 08:18 PM
You want to go from the output that says MAIN O/P. So you will need a female XLR to TRS cable.
This page should help:
http://www.sweetwater.com/shop/cables/finder.php
Old 03-02-2013, 08:32 PM
Not necessarily. In a mastering situation for exemple, one could sometimes prefer to use unbalanced connections to bypass uneeded electronic stages as to preserve as much signal purity/integrity as possible.
Darryl Ramm
Unbalanced/Balanced?????? kmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-05-2012 05:19 PM
Balanced and Unbalanced Fishman1 General Discussion 2 09-25-2005 11:27 AM
Balanced / Unbalanced pipesurfa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-26-2004 01:44 PM
balanced to unbalanced oreo1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-13-2004 07:43 AM
Balanced or Unbalanced Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-12-2004 05:38 PM
