Old 11-05-2012, 06:55 PM
PatriotsBiker PatriotsBiker is offline
Default ReWire and Reaper
I've been doing some searching and can't quite put it all together regarding using Reaper & ReWire to run VIs. I'm running Windows 7, 64 bit with 16GB RAM. PT10.3.2.
#1: Can the 64-bit Reaper run as a ReWire client from Pro Tools 10.3.2?
#2: If I can, is there a good video or instructions to set this up? I can easily bring up 32 bit by default. I can't figure out how to get it to point to the 64-bit version of Reaper.
I know I've seen people say you can and I've seen people say that you can't. I'd love to be able to use some of that RAM i bought, but cannot be used right now by Pro Tools.
Thanks
Old 11-05-2012, 08:48 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: ReWire and Reaper
Search the forum for user name spenner, Reaper, video. He has a video or search youtube.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 11-06-2012, 06:31 AM
Cheers,
I've seen that - well, the first one - and it's adding to my confusion. It states that it's only good for 32-bit Reaper.
Old 11-06-2012, 07:37 AM
I use the x86 version of reaper. Other rewire clients must be 32 bit (x86) versions as well.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 11-06-2012, 08:28 AM
spenner spenner is offline
Only 32 bit Reaper ReWire will work with 32 bit PT. How it works is, via Preferences, point Reaper 32 bit to your 64 bit VI folder, and Reaper bridges those plugins allowing access to more memory. This is the method used in the videos and noted in the description.
Old 11-06-2012, 09:06 AM
It only took 1/2 dozen times, but it finally did register.
Thanks. I'll carry on from here. Hopefully no more reading errors.
Old 11-06-2012, 10:22 AM
OK, a follow up question. I'm pointing to the 64 bit VSTs. I don't see any more RAM being used. Do I need to do something else to enable the additional RAM to be accessed?
Old 11-07-2012, 05:06 AM
Instantiate VI's in Reaper until one of two things happen: 1) You max out system memory, or 2) Reach the Reaper ReWire 16 MIDI track limit.
Old 11-07-2012, 04:01 PM
I'm sure I've got a setting off somewhere. In PT, load up Reaper 32-bit and from within, the Kontakt instance running Studio drummer. I'm running a MIDI file sending in an active, but not over the top drum track. The performance is actually worse than running it entirely in Pro tools. I'm pegging Windows CPU and memory doesn't get above that 3.2 - 3.3 area. I am indeed pointing to the 64 bit VSTs.
I'm not sure what setting is not optimalal for this. I've used your videos the best I could (blurry eyes don't fare well, but not your fault).
Now, I run everything native within Reaper and it's flawless. I think that's why I was hoping to find a source that's laid all of the instructions, connections and issues in one spot all hopefully up to date.
My system from my profile:
System Details
Eleven Rack
Eleven Rack Expansion Pack
Pro Tools 10.3.2
Pro Tools Virtual Instrument Expansion Pack
Win 7 64-bit, Dual Core, 16GB Ram
Native Instruments Komplete 8 Ultimate
Old 11-08-2012, 04:34 AM
The setup really is as straight forward as laid out in my videos. Reaper does come with a plethora of under-the-hood tweaking options. However, other than what is done in the videos, I never changed the default settings for it to work with LE 8, MP 8, and PT 9. I'd make sure that all drivers and software are up to date. (Perhaps someone can confirm whether or not the latest version of Reaper ReWire works with the latest version of PT 10).
FWIW, have you tried the VEPRO 5 demo? I use that now and highly recommend it over Reaper ReWire.
ProTools and Reaper rewire johndaw Pro Tools 9 8 07-24-2013 09:51 AM
ProTools Rewire & Reaper jayprotools Pro Tools TDM Systems (Mac) 29 11-30-2010 07:48 PM
Can you rewire Reaper in 7.4?? Dogcode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-23-2010 06:50 PM
How do I rewire Reaper music Pro Tools TDM Systems (Mac) 3 03-18-2010 01:00 AM
Reaper Rewire dave911 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-06-2010 11:00 AM
