Old 08-30-2000, 09:31 PM
Guest
Posts: n/a
Default 2-track mix back to Logic?
I was wondering if it's a good idea if I send my sequence out of Logic to my O2R, to mix it down; and then simultaneously send the 2-track mix back to Logic- has anyone done this? Any tips? Thank you.
Old 08-30-2000, 10:45 PM
Mt.Everest Mt.Everest is offline
Default Re: 2-track mix back to Logic?
Sure, This sort of thing is done all the time..
After you record the mix into Logic, play back the mix and original midi tracks at the same time to make sure you dont have any latency or drift issues...Make sure they are "phasing" as you listen back
All should be well though...
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
RE: Getting Back in...PTLE vs. Logic August Heat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 03-03-2005 12:55 AM
HD OMF to Logic & back again finally working OK ? Jules Pro Tools TDM Systems (Mac) 0 02-10-2004 06:15 PM
Logic Audio TDM is Back at the Wheel relaxo Pro Tools TDM Systems (Mac) 22 11-19-2001 11:55 AM
i'm going back to logic for midi! soosh Pro Tools TDM Systems (Mac) 4 04-01-2000 07:08 AM
PT(Mac) to Logic(PC) and back, best method? Tim R. Tips & Tricks 0 12-20-1999 10:11 AM
