Old 11-20-1999, 06:46 PM
Guest
Posts: n/a
Default Connecting External CD-Recorder
I'm going to connect an external Plextor 8/2/20 to a powertower pro 225 which has a 3940uw inside. I am using the internal fastbus for the boot drive and an individual port off the 3940uw to each of my (2) 9.1gig drives for audio, which I currently have mounted internally. The question is which is the best port to use to connect this etternal cd-burner? I have considered using one of the external connectors on the 3940uw but fear it might compromise the performance of the fast hard drives, since it is a 50 pin. Connection-wise it appears the SCSI connector on the back of the machine would be the easiest, but that goes to the computers internal slow bus I believe. Any help would be appreciated.
Thank You.
Old 11-20-1999, 07:12 PM
ppine ppine is offline
Default Re: Connecting External CD-Recorder
Connect it to the external SCSI of the PTP. I have one of my 8x plextors on it, and have had no throughput issues at all...
burn, baby burn...
Old 11-21-1999, 04:08 AM
Jonny Atack Jonny Atack is offline
I have a Plextor 822 on SCSI bus 1 on my Mac 9600. Never a throughput problem. Not even one bad burn. Bus 1 is separate from the SCSI bus 2, which has the 2940 and the Cheetahs for PT files. Works great.
www.capitolstudiosparis.com
mixing down to an external cd recorder neonknight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-09-2005 11:59 PM
More than 32 tracks using external recorder? CountZer0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-23-2005 01:32 PM
mixing down to an external cd recorder... neonknight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-04-2004 05:19 AM
Sync with an external recorder like a Korg D16 or Roland recorder yoshi68 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-17-2001 08:30 AM
sync PTF to external HD recorder Gerald-o Digidesign Hardware & Software 0 11-04-2000 02:20 PM
