42 hours of editing on ProTools 9 and thus far, I've only found 1 semi-repeatable, crash inducing bug;
When using the Import Session Data feature, often ProTools will quit before the completion of the "Updating I/O Setup" stage. Is anyone else seeing this? P MacPro 10.6.4 PTHD 9.0.0 |
Does the problem occur if you import to a brand new Pro Tools 9 session? Is there a particular track import that causes the crash (import track by track to see if you can narrow down the track that's crashing it.)?
If there is a specific track - what's on the track as far as plug-ins and routing goes? |
At first I thought it was a specific track because my workflow has been repetitive and I've been importing the same track from master sessions into slave sessions, but now I see it will happen on different tracks as well.
The crash occurs whether importing to a pre-existing template session or a brand new PT9 empty session. The crash never occurs if it's the first ISD since I've booted and I can usually get one or two separate ISD's completed. The third or fourth will crash. Please see crash-point of third ISD attempt screen grab here. |
Oh, also;
If I try to run PT9 immediately after the crash (without a reboot), I get a kernel panic on my MacPro. yay :\ |
![]() Quote:
www.PeterMoshay.com www.LiveFromDarylsHouse.com Check out new shows on the web each month on the 15th. Always commercial free, watch on Mac/PC, mobile & tablets. |
![]() Quote:
hope that helps |
![]() Quote:
Sounds to me like for now you can save some time and grief by doing the obvious and you truly want to not disturb your current I/O set up save (and might be a good time to change the name of the session first), close your session, then open up the desired session to imported from...rename it "title_IMP" or something like that and then quickly eliminate the I/O in one fell swoop from.... say all the tracks quickly by using option click remove on any one track. Close that session and reopen your session and import away with no I/O confusion to your "early release" software. At least you'll accomplish your task until AVID figures it out on their dime. They should have quite a few dimes right now shouldn't they? If it is still crashing-- then point to the plug-ins i reckon. Good luck.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
At this point, I'll stick to rebooting the whole system previous to using ISD.... It takes just a few seconds longer, but uses less brain cells.
I look forward to the day that this reproducible bug is squashed. (cs1?) |
I was wrong and studiojimi is right; you must remove the I/O set up of the session file you are going to ISD from. The reboot will not always work.
BTW- this is much more than inconvenient for those of us who are using ISD across a network. ![]() Back to 8.0.4 for me. |
I've been able to reproduce this and have it logged for a fix.
9.0.1 doesn't fix the Import Session Data crash | poly915 | macOS | 4 | 01-07-2011 02:53 PM |
Session Data import function from 8.0.4 to 9.0.0 leads to a PT crash | Franco1967 | Pro Tools 9 | 27 | 11-27-2010 04:31 AM |
New bug? Import Session Data - Crash - Missing Video | Ryan Young | Pro Tools 9 | 0 | 11-15-2010 01:33 PM |
Import session data causing crash in 8.1 | jval | Pro Tools TDM Systems (Mac) | 5 | 08-19-2010 11:57 PM |
7.4 repeatable import session data crash | fman | Pro Tools TDM Systems (Mac) | 0 | 11-23-2007 12:44 AM |
