Old 08-26-2009, 05:36 PM
magnoman magnoman is offline
Default Per 64 HELP !!!!!!! cpu will not boot
Ok,,
Have had a Magma Per 64 with a HD 4 running for two years no problems. Then a month ago started geeting all kinds of dae hardware errors.
system crashes spinning wheel, black sreeen.. Rebuilt my entire system from the ground up on a new internal drive. pulled all cards , ram , cables, cleaned all connectors ect, ect...
Ran good for three days then started having trouble again. Just having PT app open with out even a session being loaded the cpu will RESTART ALL ON IT"S OWN.
Know, can not even boot the Mac with the chassis attached! DEAD IN THE WATER...
The Apple system profiler ( pci cards ) does not see the magma host card in the cpu, and all control lights are glowing green on the host card.
When chassis is turned off cpu boots and runs perfect.
I am in the process of getting a new chassis to try but in the meantime can not work!
I have beena digi rep for 8 years and never seen anything like this where the cpu will restart all on it's own.
Anyone have any ideas ?
Old 08-26-2009, 06:10 PM
BradLyons BradLyons is offline
Default Re: Per 64 HELP !!!!!!! cpu will not boot
Perhaps the cable is bad or even the PCI card that connects into the computer? Do you know anyone that has a similar setup that you can test these?
Thank you,
Brad Lyons
www.howavl.com
Old 08-26-2009, 06:45 PM
Yeah , I tried a new didi link from the 192.. there are two control cables from the magma host card did not try those but the system should be able to run with just one cable?
I guess have to wait till I get the new chassis to try and see if the the host card , chassis or both..
I called magma to try to get a new control card and they say they do not make it any more and I need to upgrade the chassis to all new internal boards...
yeah $1500 !
Old 08-27-2009, 01:57 AM
digidesigner digidesigner is offline
loose the magma and put three of the four cards in CPU to see if the CPU is ok
Old 08-27-2009, 02:08 AM
crizdee's Avatar
crizdee crizdee is offline
I'll take a guess and say like 99% of pe6r4 users his computer will be PCIe. so putting cards in the computer is not an option.
Ironically i had bad boot-up problems yesterday and couldn't get PT to run until i removed one of my cards from the pe64r been working fine then without warning it just failed.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-27-2009, 12:21 PM
DHG MUSIC DHG MUSIC is offline
There is a great possibility that your power supply is going dead
when you start having that problem, some of the cards do not get the correct amount of electricity, therefore the chips , or the plugins on those chips, are seeing in Protools like faulty
I bet you you are having a lot of DAE -7401 errors
If this is the case try getting a new PSU and also the 12v resistor that magma provide
HTH
I used to be insecure...now I'm not really sure
Old 08-27-2009, 02:22 PM
the dude's Avatar
the dude the dude is offline
The PE64R chassis only has one cable not 2
so either you don't have a PE64R or you were sold a retrofit
card that went into that chassis
I had this issue with that same cause
my client was sold a magma card that fit in the older chassis
and it would just shut down all the time
I've seen this also with a bad digi card, and a bad display
card on differant occasions
also. FYI the system profiler will NEVER see the magma host card
unless the chassis is on and functioning
so with the chassis off or disconnected it shows that slot empty
the iniband cables go bad also I have one here to prove it
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 08-27-2009, 02:56 PM
crizdee's Avatar
The PE6R4 has 2 infiniband cables the later PE6R4-I has 1 i-pass cable.
Chris
Producer, Engineer,
www.ukmastering.com
OT: PT-Win 7 / XP Dual-Boot; Question re: Win 7 Install, Boot Manager Files taylor4814 Windows 1 02-16-2012 05:54 PM
Mac Pro won't boot Stig Eliassen Pro Tools TDM Systems (Mac) 10 04-06-2011 01:57 AM
Boot Camp - Dual Boot, Dual Versions of PT LE? bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-17-2009 04:15 AM
Boot from CD ? Bryan Cole VENUE Live Sound Systems 2 08-14-2007 11:29 AM
Cant Boot Up bearwax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 04-23-2001 04:29 AM
