Old 05-05-2020, 08:58 PM
delrizian delrizian is offline
Default MIDI Issue with external keyboards
Please help with a MIDI issue as I’m at my wits end! When using my Roland or Korg keyboard as a sound module with Pro Tools, I can record or playback. But when I RECORD I’m hearing not only the midi patch selected in ProTools, but also the patch on the keyboard at the same time!
On the Roland you have to set it in “performance” mode and you have to use Sequence mode for Korg. I want to use the keyboards as sound modules. I dont like virtual synths.
For example Rolands performance mode when I record, i’m hearing not only the MIDI patch selected in Pro Tools but also the performance patch on top of it…I’ve tried different settings to no avail, local is set to off.
How do i hear only the keyboard sounds i want from the MIDI patch selected in Pro Tools ?
Dave
Delrizian Studios, Fort Lauderdale, FL. "The Music Is Out There..."
Using Pro Tools HD TDM, Mac 10.5.8, Pro Tools HD 8.0.1cs1, Powermac dual G5, external 1TB G-drive.
Old 05-05-2020, 09:30 PM
Top Jimmy's Avatar
Default Re: MIDI Issue with external keyboards
If you want to use the keyboard as your sound module, there is no “patch” in Pro Tools. You should have a midi track and an aux track, and local control on the keyboards should be turned off. The input of the midi track is the midi out from the keyboard. Likewise, the midi out from the track should be to the midi in on the keyboard. The analog out from the keyboard is then routed through the aux track for you to monitor. Record enable the midi track and you’ll only hear the output from the keyboard.
James Cadwallader
External Keyboards unreliable on MacOS with 2019.5 TKellzzz macOS 5 06-22-2019 06:24 AM
Protools 9 sync with external keyboards Aster Windows 3 03-13-2013 01:10 PM
MIDI timing issues using external keyboards and a 002 affluence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-24-2008 11:19 AM
sequencing external keyboards with 002 rmpc2500 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-30-2005 06:02 PM
MIDI Recording in Win98 Protools LE and keyboards...Can I use non-General MIDI sounds Shan Plourde General Discussion 2 01-18-2001 08:34 PM
