Old 06-25-2013, 10:01 AM
c-post c-post is offline
Default how to get ZIP working
I just installed Express ZIP on my 10.3.9 Mac. I think. However, it is not working. Can someone recommend a zip program for legacy mac that works, and how to use it? I need to get this protools session zipped.
thx
c-post
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 06-25-2013, 10:32 AM
jryser's Avatar
jryser jryser is offline
Default Re: how to get ZIP working
Use unstuff it or a third party unzip. OS will just run you around in circles. !
Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 06-25-2013, 10:59 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
You can compress using a couple of things you already have...
right-click and choose Archive should zip a file or folder, I think even on OS X 10.3.
Or if you are sharing with another Mac user, you can use Disk Utility to create a compressed DMG.
If you absolutely need to create ZIP files to send, then I would suggest Stuffit or Stuffit Deluxe. Email them and ask if they have an older version that will work on your OS:
www.stuffit.com
(the current version won't, but you may be able to buy the current version and get access to older installers)
Just saw this:
http://www.stuffit.com/support/updates.html
10 10.0.2 English StuffIt Standard 10.0.2 Mac 9.3 MB .dmg This installer will require a StuffIt Standard 10 serial number in order to not expire, but will act as a 30-day trial if not registered.
For Mac OS 10.3-10.3.9
Not sure if that will include zip format, but you can certainly check it out.
Bruce Paine
System Details
Old 06-25-2013, 11:44 AM
Great Jeff and Jryser. I am back in business. The control click command comes up as "create archive..."
thank you
c-post
Old 06-29-2013, 08:29 PM
Sonny Keyes Sonny Keyes is offline
I love this one:
http://www.yellowmug.com/yemuzip/
Sonny Keyes
Toronto
http://www.sonnykeyes.ca
Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20
Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10
Digi 002 - optical input not working / only DI channel 1 working Maulden7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-07-2013 01:46 AM
Mp3 not working and my key focus e not working vanquished1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-02-2009 09:42 AM
Strike 1.5 upgrade - not working because of iLok-working now gryphondale Virtual Instruments 0 01-27-2008 09:23 AM
digital i/o...working? Not working? ThomCat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-18-2001 08:43 PM
VIA chipset: working/not working Tomek S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-02-2000 07:29 AM
