Old 03-07-2018, 11:00 AM
piedpiper piedpiper is offline
Default Mbox Pro 3 not recognized on Sierra
Been using Protools for years using a BLA modded 002R and a 2011 iMac. I recently bought a used Mbox Pro 3 for my daughter and am trying to test it out for her with my girlfriend's 2015 MacBook Pro using the Firewire to Thunderbolt adapter and nothing here either. Running Sierra on both. Haven't dared to update to High Sierra. I have the latest drivers and Protools. Not showing up as connected. Is this definitely a driver thing? Is there no option but to wait for Avid to fix it with new drivers? Anyone have luck with this?
Old 03-07-2018, 01:35 PM
reichman's Avatar
reichman reichman is offline
Default Re: New Mbox 3 Pro Driver Needed for Pro Tools 2018.1
On my home system, MBox Pro 3 working 100% with High Sierra 10.13.2. This is a supported config. Not sure why it wouldn't be seen.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-09-2018, 12:03 PM
What computer are you using? And are you using a firewire to thunderbolt adapter?
Old 03-09-2018, 12:10 PM
reichman's Avatar
Mac Pro 6,1. Thunderbolt 2 to Firewire adapter.
Firewire cables can be flaky. Try a different cable, and do whatever you can to get a FW800>400 cable. The 800>400 adapters are a pain. Also make sure you have Mbox Pro app available to troubleshoot.
Nathaniel Reichman
Old 04-08-2018, 03:04 PM
arekhgr arekhgr is offline
Default Re: Mbox Pro 3 not recognized on Sierra
I have the same problem. :/
Old 05-27-2018, 08:24 AM
Fadda Fadda is offline
Has anyone been able to sort this out? I’m having the same issue.
Old 05-28-2018, 10:35 AM
eggbox eggbox is offline
I had the same problem but have finally found the solution after a lot of head scratching. Hopefully you did the same thing as me anyway and this fixes it for you.
I remembered when I installed the driver a pop up came up and in my haste to get things working (ironically) I didn't read it and clicked OK (In blue making you think you should press it) and carried on the installation. Anyway, that pop up was the critical part, you need to click to allow extensions by "Avid Technology Inc".
No matter how many times I uninstalled and reinstalled the Mbox Pro 1.3.5 driver I couldn't get the pop up to display and I couldn't see a way to manually add the extension exception.
This is how I fixed it.
1. Uninstall 1.3.5 driver
2. Install the incorrect Mbox (Not Pro) driver 1.2.13 but this time clicking 'Open Security Preferences' and adding the exception for extensions by "Avid Technology Inc".
3. Unistall 1.2.13
4. Install 1.3.5 driver again
The Mbox Pro now works!
I hope this helps.
Old 06-30-2018, 10:28 AM
CharlotteMichele CharlotteMichele is offline
You are a GENIUS!!! Totally worked.
Anyone got TDM cards be recognized by Mac OS Sierra ? tonwurm Pro Tools TDM Systems (Mac) 5 07-31-2019 09:29 AM
MAC PRO High Sierra & PTHD 2018 can't recognized PCIe Native card Sutee Sangsareechon Pro Tools 2018 1 05-11-2019 04:48 PM
Mbox 2 Mini x Mac OS Sierra HELP alicealissa FireWire & USB Audio Interfaces (Mac) 4 11-29-2017 10:30 PM
Mbox 3 with High Sierra francois FireWire & USB Audio Interfaces (Mac) 2 10-11-2017 04:55 PM
Mbox 3rd gen + MacOS Sierra Darkzeh FireWire & USB Audio Interfaces (Mac) 11 08-02-2017 05:25 AM
