Old 04-18-2010, 07:10 PM
glitchbent glitchbent is offline
Default Pro Tools LE (7 & 8) "creating DAE objects" freeze
Hi there! I was successfully running PTLE 7.0 on WinXP for about 4 years. And suddenly the other day, it started freezing on "Creating DAE Objects" upon starting up. Same symptoms as everyone else on DUC; cannot end process successfully, trying to shutdown hangs and never completes.
Here are the steps I've gone through, with the problem remaining consistent:
- On every boot-up I always do the "Delete DAE and Pro Tools preference files" and "Delete the Digidesign Databases folders for all hard drives" steps from the "General Troubleshooting Pro Tools LE on Windows" forum on DUC and then clear my trash.
- I have made sure my Pace Drivers are current.
- I have updated to the latest CS release.
- There are no other devices plugged in to my computer other than ilok, mouse, keyboard, and digi002.
- I have tried both my firewire ports.
- I am always logged in as the admin.
- I tried removing and re-installing pro tools.
I then, in an act of desperation, purchased PTLE 8 online and installed it (pretty excited about this, actually). But I STILL have the same issue where it hangs on "Creating DAE Objects."
I am thinking that it isn't a problem with my cpu or firewire card, since it has worked fine for 4 years.
And It isn't a PTLE 8-exclusive problem, since the exact same thing happened to me on PTLE 7 first.
Now, If you have any steps I should do that I have already tried, I'm fine doing them again. I'd rather re-do all of them from step 1.
Thank you so much for all of your time and help! I love Pro Tools and hope to be a long-time user.
Any advice?
-Chris R
PS: Here is my system profile from Sandra Lite:
Computer
Model : Dell Precision WorkStation 380
Workgroup : WORKGROUP
Host Name : GeneralSpecific
User : General Specific
Processor
Model : Intel(R) Pentium(R) 4 CPU 3.80GHz
Speed : 3.8GHz
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Integrated Data Cache : 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector, 2 threads sharing
Computer
Mainboard : Dell 0CJ774
BIOS : Dell A06 01/09/2006
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.5GB ECC DIMM DDR2
Chipset
Model : Dell 82955X Memory Controller Hub
Front Side Bus Speed : 4x 200MHz (800MHz)
Total Memory : 4GB ECC DIMM DDR2
Memory Bus Speed : 2x 400MHz (800MHz)
Memory Module(s)
Memory Module : Nanya NT1GT72U8PA1BY-3C 1GB ECC DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3)
Video System
Video Adapter : ATI FireGL V3100 (4 PS2.0, 2 VS2.0 391MHz, 128MB 195MHz, PCIe 1.00 x16)
Storage Devices
SAMSUNG HD160JJ/P (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 149GB (C:)
Seagate ST3500641AS (500.1GB, SATA300, 3.5", NCQ, 16MB Cache) : 466GB (D:)
HL-DT-ST DVD+-RW GWA4164B (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
Hard Disk (C:) : 149GB (NTFS) @ SAMSUNG HD160JJ/P (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache)
Hard Disk (D:) : 466GB (NTFS) @ Seagate ST3500641AS (500.1GB, SATA300, 3.5", NCQ, 16MB Cache)
Optical Drive (E:) : N/A @ HL-DT-ST DVD+-RW GWA4164B (ATAPI, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Intel 82801GB/GR (ICH7) LPC Interface Controller
LPC Legacy Controller 1 : SMSC SCH5504-NS
Audio Device : Dell 82801G (ICH7) High Definition Audio
Audio Codec : Sigmatel 9200 HD Audio Codec
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : Dell 82801G (ICH7) Ultra ATA Storage Controller
Disk Controller : Dell 82801GB I/O Controller Hub SATA cc=AHCI
USB Controller 1 : Dell 82801G (ICH7) USB Universal Host Controller
USB Controller 2 : Dell 82801G (ICH7) USB Universal Host Controller
USB Controller 3 : Dell 82801G (ICH7) USB Universal Host Controller
USB Controller 4 : Dell 82801G (ICH7) USB Universal Host Controller
USB Controller 5 : Dell 82801G (ICH7) USB 2.0 Enhanced Host Controller
FireWire/1394 Controller 1 : Dell FW322/323 IEEE1394 OHCI FireWire Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft Office Document Image Writer Driver (300x300, Colour)
Printer : HP Officejet 6200 series fax (USB, Colour)
Printer : HP Officejet 6200 series (USB, Colour)
Network Services
Network Adapter : Broadcom NetXtreme 57xx Gigabit Controller - Packet Scheduler Miniport (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 2)
Platform Compliance : x86
Old 04-18-2010, 08:05 PM
Cloud_9 Cloud_9 is offline
Default Re: Pro Tools LE (7 & 8) "creating DAE objects" freeze
You said you tried both firewire ports, I would like to see what happens when you only have one of them enabled. Give that a shot first. Make sure all other adapters are disabled.
More than one active firewire port has proven problematic in the past, especially hanging at "Creating DAE objects".
Is that audio card disabled? How about that codec? Do you use this PC for anything other than PT? Hope not.
If you still experience hangs, try shutting off your 002. You might find that you can end the process successfully.
Hope this helps.
PT11, Windows 10
RME Babyface
Old 04-18-2010, 08:26 PM
Shutting off my 002 allowed me to quit PT thankfully! Now I dont have to reboot every time! Thanks!
Ok, I'm going to try to disable one of the firewire ports. How do I disable just one port rather than the whole card?
The main audio card is not disabled, but that was never a problem before. I guess I'll try that if the firewire disable doesn't work.
Thanks so much!
Old 04-18-2010, 08:31 PM
Regarding my audio drivers;
In device manager, under "Sound, Video and Game Controllers" it lists the following:
Audio Codecs
Digidesign Digi 002
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Any suggestions as to which I should try without first? Other than the Digidesign one, are any of these vital to PT?
Old 04-18-2010, 08:34 PM
GAH NEVERMIND!
It was the damn unauthorized moogerfooger plugins! I moved them to "unused" and now it all works! (I hope)
I will try to get some work done, restart the computer, and let you know if it really did fix it.
Thanks again!
-Chris R.
Old 04-18-2010, 09:05 PM
Nevermind
I restarted the PC and now it still hangs on "creating DAE objects."
I was so excited D:
So back to disabling a firewire port or an audio driver. Refer to my previous posts please.
Old 04-19-2010, 05:16 AM
Thanks so much!
Well, you cannot disable just one port on the card, I was figuring your motherboard had an additional firewire port that was perhaps interfering. I dont think that your firewire card is the problem. I am assuming your firewire adapter is a Texas Instruments chipset? Do you have any other network adpaters active? They should be disabled.
I would get rid of that codec, havent heard of codecs making problems before but just in case.
Another thing comes to mind, make sure your 002 is ON Before turning on your PC. This has helped some users before and it is my case as well.
I know your system worked before, but small changes make BIG problems for PT sometimes.
If none of this works, you might also try moving up to XP SP3, and updating PT to 8.0.1, which has resulted very stable for me, but before this, do the above.
Good Luck!
PT11, Windows 10
RME Babyface
Old 04-19-2010, 01:38 PM
I always turn the digi002 on first. But thanks for the tip.
Ok, so I only made one change, I disabled "SigmaTel High Definition Audio CODEC" and it worked.
Then I rebooted, tried again and it hung on "Initializing Globals" this time.
Oh, and sorry, I'm running PT 8.0.3
I think I forgot to make that clear.
You know, I think you're right about there being an additional FW port. Yep, there's one on the front of the pc. But I can't seem to pinpoint it in my device manager. Just for the f*** of it I disabled two unused serial ports too.
I'm gonna restart and then I'll see if anything works.
Be right back.
PS: thanks again for the continued help.
Old 04-19-2010, 02:11 PM
>:l
Well now I turn on the PC.
Open protools.
Hangs on "creating dae objects."
Hard-power-off the digi002.
Error message lets me exit protools.
Power-on the digi.
Pro Tools works.
WTF?
Old 04-19-2010, 04:41 PM
Originally Posted by Cloud_9 View Post
Good Luck!
BTW, thanks for the help! I just emailed in my project that was due
PS: It was a hip-hop remix of Bon Jovi's Shot Through the Heart...
freeze on "creating dae objects" jloakland Pro Tools TDM Systems (Mac) 1 06-27-2011 12:29 PM
PT9, Win 7 64 bit & "Creating DAE Objects" freeze The Bagwhan Windows 5 12-08-2010 01:35 AM
Freeze on "Creating DAE objects" gossamer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 10-25-2010 09:46 AM
Pro tools 8 freezes at "Creating DAE objects" babydolla1 Pro Tools TDM Systems (Win) 0 06-15-2010 03:44 PM
System Hangs on "Creating DAE Objects" In Vista 32 w/ Digi003 Rostafunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-19-2009 02:18 PM
