Using the Stompbox Plug-ins with Eleven
How are you guys using these? Do I just instanciate stompboxes in the slots before Eleven? What about adding the spring reverb to an amp? It looks like there is a cab only version of Eleven, so I could disable the cab in the main plug-in, insert reverb, then insert the cab. The reverb would still be post power-amp, though. I guess it supposed to be a three knob standalone tank so it could as easily just go in the front end of the amp.
Just making sure that I'm not missing something clever about chaining plugins within Eleven or something. |
Re: Using the Stompbox Plug-ins with Eleven
Yes as you discovered you have the cab only plugin and can bypass the cab in the standard plugin, so you can insert affects between the two if you want (or use third party cab sims/impulse loaders). Something to play with... but to be clear there is no emulation with Eleven/Eleven Mk II or the Eleven Rack of a real effects loop (FX loop return prior to the amp power stage).
If you want to waste lots of time playing with stuff. Bias Amp is neat and you can "unlock the signal path" and create a before effects loop and after effects loop amp components and other routing to play with stuff. Easy to waste lots of time I expect other amps sims let you do that as well, but I don't know which ones. |
Stompbox delay with midi controller | madlo | Eleven Rack | 4 | 03-31-2011 06:41 AM |
Stompbox mode and the FCB1010 | vinceh | Eleven Rack | 0 | 01-31-2011 06:52 PM |
Anyone know a good distortion stompbox plugin? | Audioartist | VENUE Live Sound Systems | 8 | 05-18-2010 02:47 PM |
Using a stompbox on Vocals thru PT6.1? | pribb1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-23-2004 06:59 PM |
OT: Distortion stompbox reccomendations | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 01-23-2004 10:39 PM |
