Re: DAE ERROR 6 - Any help will be appreciated!!
I also have error 6 sometimes. For me the solution is, as recommended in a thread here on the DUC, deleting the wavecache file in the session folder.
Worth a try, I guess.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
thanks for that suggestion, but unfortunately no luck, still the same, I am actually backed in to a corner and a delivery deadline looming, I may have to go back and start again probably in studio one which is going to be a major pain as I am just doing final tweaks now on a project started back in october last year
This worked for me.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
I actually found a corrupted file in the session that when I consolidated it the problem went away for now, I had to make all the tracks inactive one by one, it would be on a session where I had over a hundred tracks running so relieved to get the mix finished though, it has been going on for a couple of weeks, I havent been mixing the track for that long, just tweak cycles in between other sessions :)
I still have other sessions with the same issue so I am going to look for bad files in them, not convinced its over but all good for today :) |
I had this error a while ago (actually AAE Error 6) so check this thread for some other thoughts: http://duc.avid.com/showthread.php?t...ight=AAE+Error
I had this problem, exactly as you described it, about a year-and-a-half ago. Drove me crazy, and, alas, its a short drive. It turned out to be a disk error, or rather, a disk connection fault error.
Get Acronis Drive Monitor http://www.acronis.com/en-us/homecom...drive-monitor/ or any of the other SMART data readers. SMART (Self-monitoring, Analysis and Reporting Technology) is a built into most all hard drives these days and reports a lot of disk performance parameters. It's used primarily in data centers to help predict when a drive is about to go south so it can be swapped out. I found that the drive I was using that was generating all the DAE Error 6's was seeing high levels of "UltraDMA CRC Error Count", while all my other disks were seeing zero of these errors. DMA (Direct Memory Access) is the way fast transfers are made between a disk drive and RAM in a computer. I was able to re-seat all the SATA connector in the cable between the drive and the mother board and the problem went away. I discovered some other things with the SMART reader also, such as one of the drives I had bought inexpensively had over 30,000 hours, over 3 years, of run time on it when I bought it. Apparently when large data centers swap out drives to get new technology, they resell used drives that are functioning well. The only way to find this stuff is with a SMART reader program. Good luck. |
Elastic audio quantizing error - Help appreciated | darrengold | Pro Tools 10 | 0 | 01-27-2013 01:13 PM |
Your help is appreciated | r11k11d | Pro Tools M-Powered (Mac) | 0 | 10-18-2012 05:08 AM |
New to it all so any help is appreciated | Smoo10 | Pro Tools TDM Systems (Mac) | 0 | 01-19-2011 06:24 AM |
DAE (-9073) Error - Insight Appreciated | thom1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 08-29-2010 05:07 PM |
9073 error , Any help would be appreciated | postman56 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-19-2007 12:45 AM |
