Old 01-02-2018, 08:03 PM
adam79's Avatar
adam79 adam79 is offline
Default Plugin Automation
I'm trying to figure out how to automate effects while moving multiple knobs at once. I want to automate the EQ so the HPF increases while a boost in the low mids moves up in frequency simultaneously. However, I can only adjust one knob at a time with the mouse. Is this possible?
Old 01-03-2018, 12:48 AM
Stig Eliassen's Avatar
Default Re: Plugin Automation
One at a time without a console. You can't "rubber-band" parameters and have them maintain their relative offset, if that's what you're thinking.
Old 01-03-2018, 05:13 AM
Try using multiple automation lanes if you truly want to automate things. But you have to do each lane separately; tricky but it can be done.
Jack
QAPLA!
Old 01-03-2018, 06:09 AM
adam79's Avatar
So you can record each knob's movement separately, and then combine them all? Ill have to search for "automation lanes" in the manual. Thanks.
Old 01-03-2018, 06:10 AM
adam79's Avatar
If That's what I'm thinking then I'm wording,it,different.. I have no,idea what rubber banding parameters means, as well as their relative offset.
Old 01-03-2018, 06:19 AM
Like Jack said, you can automate virtually every plugin parameter separately. Your initial post led me to believe that you wanted to write moving automation for multiple parameters simultaneously, and that can't be done without some form of console.
Old 01-03-2018, 10:10 AM
You don't 'combine' anything. Each automation parameter runs only whatever control you have it assigned to; that means you can tweak each one separately to get what you want.
Jack
QAPLA!
Old 01-03-2018, 12:30 PM
Top Jimmy's Avatar
If you like writing automation organically, be sure to be in touch mode and you can automate the first parameter on one pass and the second parameter on the next pass.
Or you can pencil edit the moves in the automation lanes.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Copy plugin automation to another Plugin? sjtae Pro Tools 12 1 08-24-2017 11:37 PM
Automation, Plugin, write-to-all-enabled, but only for the currently targeted Plugin joachim Pro Tools 10 3 07-11-2012 09:48 AM
Where'd my plugin automation go?! scottgreiner Pro Tools TDM Systems (Mac) 10 06-15-2010 11:10 PM
Automation of Plugin jc335 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-16-2008 09:24 AM
Plugin automation optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-25-2003 06:07 PM
