Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 05-12-2019, 10:02 AM
Cheesehead Cheesehead is offline
Default Default to Pan after aux and plugin selection?
I always used to use PT control for its function of following and showing the relevant Pan settings on the app as you move around different tracks.
Now following Aux and Plugin have been added, I can see myself using those a lot also. Brilliant new feature by the way.
I wondered would it be possible to have the app default back to pan after closing an Aux or Plugin? Ie select Pan on the app in the tracks window- when you select an Aux it shifts to Aux on the App, when you close the Aux it defaults back to Pan on the App, rather than staying on Aux as it does now?
This would be a brilliant extra feature.
Mac Pro 6,1 12 core, OSX 10.12.5, HD-Native TB, Trinnov MC, 888 IO, 192 IO, Sync HD, AJA IO XT, MC Mix, PT Control, Eucon 19.5, PT 2019.5
Old 05-13-2019, 09:24 AM
EddieJones's Avatar
Default Re: Default to Pan after aux and plugin selection?
Nice idea, I'll add to the list of things to look at in the future, Thanks
Setting to make plugin selection in DAW follow channel selection? polyh3dron Pro Tools | S6 12 01-15-2019 11:46 AM
Random Plugin Selection/Plugin Selection Shortcut issues thebeatless Pro Tools HDX & HD Native Systems (Mac) 10 08-05-2014 10:52 PM
Default selection length MFPBand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-30-2012 04:09 PM
Default Session Timeline Selection Charbs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-10-2009 06:33 PM
Default plugin preset Jakob Clemen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-17-2007 08:33 PM
