Pro tools 12.5.2 to work with digi 002
Trying not to sound like a whiner (but). I had a fall last year and now a quadriplegic. I can type with my thumb and operate a mouse with 2 hands. Used to play five instrument, no longer the situation. I have gotten pretty good with virtual instruments but my PT 8.04 would not hang with the load. I do not work any longer so I live on disability hens my problem about not buying a new audio interface. I was able to buy the LE to PT 12 cross grade using my digi 002. I downloaded the 002 and 003 drivers as recommended but when I powered on and started PT it would not accept the audio engine. I searched on line and found that I had to trash the preference file. So I did. The system booted up. OK now I'm happy. That happiness did not last. I began the midi setup process. After a long time I was able to get sound and recognition of my korg N364 (no usb) in a midi track but was unable to access an instrument track. I finally opened an a midi track sent it to an aux track which I opened Xpand2 and was able to assign sounds. I felt I could live with that. The next time I opened PT it would not allow the audio engine again. So here I go again, deleting the preferences file again empty trash and reboot. PT opens again. Now I have to start the midi process all over again (whew!). Really I did this many times, lost count. Are you getting tired yet? I am. So I get back on line and start searching again for help. I try loading the drivers for digi 002 PT 9.08 got worst. Does anybody out there no how to accomplish this task. My physical limitations leave me in a situation that recording and working with PT's is one of the few things I can do. Thank you for your help. |
Re: Pro tools 12.5.2 to work with digi 002
I know that the digi 002 is not being supported. This may keep someone from putting that info on the forum. If you know how to do this you can email me directly. [email protected]
Thanks! |
Finally got midi and instruments configured and working. All on my own.
Now to get the audio recording. Wish me luck! |
Audio problem was HUGE! I plugged in the wrong cord. OOOPS! Still have to open midi track and route it to an instrument track to make the instrument track work. To use the korg sounds I set the midi track send to an aux track. Every time I save a session and open another it says not communicating with the m-audio keyboard but it is. I'll live. Until I tomorrow and it doesn't work. WAIT......... did I solve all my own problems? Maybe someone can tell me why my instrument tracks can't just be set to no input and 1-2 out and still get sound.
I'm so embarrassed. I get on here and type my thumb off begging for help and then I go and fix all of my problems. The midi routing problem was solved by moving my session to a hard drive that was not connected with a usb cord. That may help someone else. I have friend with pro tools that I help from time to time and I tell them that it is usually user error. Now lets go make music!.......... not frustration.
The midi routing problem was from opening a pt 8.04 session. When I open a new session on the correct hard drive everything works perfect. I also had to disable the application manager. So yes you can run PT 12.5.2 on a digi 002, on windows 7 professional.
Okay! FINALLY! I have found and fixed all of the problems. It really was one problem. The firewire that was built in to my computer was not getting a steady signal. I did a search and found a list of approved firewire cards for the digi 002. Went on ebay and 3 days and $14.00 later the initialization issues were gone for good. i didn't have to disable my account manager or anything special. I do have asio4all audio driver installed but I'm not sure I even need it, but if It's not broke, you know the rest.
SOOOO, lemme get this straight. Can my DIGI 002 actually work with ProTools TWELVE on OS X?!
Didn't I read somewhere, sometime back around Version 10 or 11, that the DIGI 002 was dumped? Please say it can work? *fingers crossed*
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
The 002 isn't officially supported, but as long as there are drivers for your OS, it will probably work.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Pro Tools 12 and Digi 003 console to work on a mac | mhafftka | Pro Tools 12 | 4 | 11-18-2015 10:05 PM |
fader Digi 002 does not work with pro tools 10 | Erison Valério | Windows | 3 | 08-01-2014 04:12 PM |
Can't get Pro Tools to work with my Digi 002 | Captain Whisky | Pro Tools 10 | 7 | 06-21-2013 03:23 PM |
Does Pro Tools Le 8, Digi 003 and G5 work as a rig? | rbronniemac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-30-2011 10:47 AM |
Digi-001 (v6.4) sessions work with Pro-Tools USB-Micro? | ANDYPROFANE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-17-2008 04:20 PM |
