Old 08-04-2013, 02:08 PM
GRock41 GRock41 is offline
Default iLok has stopped working, OS 10.4.11
OS 10.4.11
MacBook Intel Core 2 Duo
2 GHz
Processors 1
Total Number Of Cores:2
Memory:2 GB
Bus Speed:667 MHz
I have been having non-iLok, performance related issues with my computer. I took it to Apple on Friday and Apple Genius person located constant stream of error messages in Console, said they were slowing my computer down. He did something to stop the error messages, now iLok does not work. Could it be coincidence that immediately following his tampering the iLok is not functioning....?
1 iLok connected via a USB hub with 4 ports, I have checked them all, and also computer USB connections. I have tried to iLok in all USB options.
iLok authorizes the use of RTAS plug-in Strike 1.0.2.6036 by Didgidesign.
I use ProTools LE 7.4 with MBox 2.
I had no problems with iLok until today, first run of ProTools after visit to Apple store.
Now i receive the message:
"This version of Strike requires authorization again in order for you to continue using it. Please press the "Buy" button to begin the reauthorization process."
When I press the 'buy' button I get the following error message:
During the current process, an error has been detected with your iLok. Please go to iLok.com and submit a RMA From to PACE. You will need to return the iLok to PACE for replacement.
ID: ePay : 14087 / Dngl : 283
Could this be a PACE drivers issue?
Also, I had a look at the RMA submission and returning the iLok. Am I right in seeing that this process costs me in the regions of £50.00??!! What's up with that?
Thanks
Old 08-04-2013, 05:07 PM
Lightbulb Re: iLok has stopped working, OS 10.4.11
Legacy InterLok Mac OS X extensions installer. Run the applicable installers within that .dmg file and see if the issue persists.
If the green LED on the iLok is lighting up, then it is more likely to be a software issue. If it is a hardware issue, there will be some cost involved in getting the iLok replaced.
Old 08-05-2013, 07:09 AM
Default Re: iLok has stopped working, OS 10.4.11
Hello
Yes, I did run the legacy extensions installer, but it has had no effect. The iLok is at least recognized by my System Profiler and I plugged it into a MacBook Pro at the Apple Store, which also recognized it. Does that count for anything? What kind of software issue are we talking about here? Can I do any diagnostics to get an idea of the source of the problem?
It is $95 to get a replacement dongle!!
Thanks
Old 08-05-2013, 12:35 PM
Take your iLok to another similarly equipped Pro Tools system and see if it recognizes it. If it is recognized, then it is a software problem. If not, then it is a hardware problem.
Old 08-06-2013, 09:49 AM
Well, that's easier said that done. I don't know anyone with an MBox 2 running ProTools 7.4. What about plugging the dongle into a Mac that can run the new iLok License Management software? Can I find anything from that?
Old 08-06-2013, 10:59 AM
Post Re: iLok has stopped working, OS 10.4.11
That would confirm the iLok and its assets are readable by the License Manager.
Old 08-07-2013, 01:48 AM
By 'assets' do you mean my plug-in license? I only have one. And if that is 'readable' does this mean that the iLok itself is working but some software is not? If it is a software issue, which software is it? How do I find out and how do I replace it? Usually with software issues one de-installs the faulty program and re-installs the clean program. I would really like to be able to rule out software before sending the dongle off to be replaced. My concern is that if is a software issue and I replace the dongle I will still be in the same position of having to deal with problematic software.
Thanks for your responses. I am groping around in the dark as I am not technically knowledgeable in these matters and the PACE support has been next to non-existent.
Old 08-07-2013, 02:23 AM
Top Jimmy's Avatar
Since the iLok operates at the kernel level, your best option is to reformat the hard drive, install Tiger fresh and then reinstall everything else necessary.
Parroted by me & Tapasquawk
James Cadwallader
Old 08-07-2013, 07:55 AM
YYR123's Avatar
YYR123 YYR123 is offline
Thanks
Nope I will sell you one for $30..... just saying....I had to put that out there...
Daniel
Old 08-07-2013, 09:57 AM
Thanks for your reply. Sorry if I come across as as a little slow, but this is new ground for me.
How would I/will I know that my iLok operates at the kernel level, and can you explain to me what that means? Bear in mind I have not yet been able to run it with a new version of the License Manager software. I have only had it plugged it to my old Mac and into a brand new MacBook Pro, both of which recognize it in the System Profile (is this the kernel level?)
I'm going to hire a Mac engineer to look at my machine so any information you can offer is really, really useful.
Thanks
iLOK activation was working then stopped ADFJamesAudio Pro Tools 11 4 06-23-2013 07:57 PM
ilok authorization stopped working. help please mixskywalker Tips & Tricks 2 04-17-2012 03:00 PM
ilok authorization stopped working. help please mixskywalker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-21-2012 09:07 PM
Why Has Ilok Suddenly Stopped Working kimballob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 07-24-2008 06:03 PM
Ilok just stopped working! beech Pro Tools TDM Systems (Mac) 9 10-06-2003 08:56 PM
