Creating New Input Paths
Hi everybody, Benson here.
This is my first post, so I apologize if I initially leave out any info that you're used to seeing right off the bat ... I've seen earlier threads discussing what I'm about to ask, but have yet to find a solution to my problem so I figured I'll just start a new discussion. I just got a new iMac running OS Sierra, Pro Tools 12, Focusrite 2i4 interface. I'm attempting to get the interface to properly communicate with Pro Tools but am running into problems with the input paths. I first pulled down the 'Playback Engine' menu and switched to the focusrite, then went to 'I/O' and everything in the 'Input' menu is totally greyed out. I cannot delete existing paths (when I open saved sessions from before I upgraded my equipment) and when I create a new session there are no paths to delete. The buttons for creating a new path or selecting default path are also grey and un-clickable. Output paths are fine, busses are fine ... just input. Any help would be greatly appreciated, and again ... I apologize for the repetitive discussion on this topic, just really hoping I can find my way through it. Thanks! |
Re: Creating New Input Paths
Hey everyone,
I actually just had help from a buddy of mine and got the problem solved, so I wanted to share with you incase it can help anyone else. The newly updated OS, for whatever reason, shows the Scarlett 2i2 & 2i4 as separate input and output sources. To fix this you need to go to Applications > Utilities > Audio Midi Setup. Click the + icon on the lower left hand corner, check mark the two Scarlett sources listed and apply that as the selected Aggregate Device. Go back into Pro Tools, change the playback engine to the newly created aggregate device, and this should allow you to utilize the 'Input' section of the 'I/O' menu |
Stereo HD Native Low Latency monitor paths are a no go with active surround paths? | vieris | Pro Tools 12 | 3 | 07-27-2015 06:07 PM |
No active input paths (again) | tokyofan | Pro Tools 11 | 6 | 06-09-2015 08:00 AM |
Invalid input paths bug?? | Soundburst | macOS | 3 | 12-11-2012 03:02 PM |
Input paths not available w/ Mbox2 mini in PTLE 8.05 | SFpete | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-17-2011 05:35 AM |
Audio Input Path Selector can't see first paths. | AlainZagar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-28-2010 10:05 AM |
