Old 10-28-2010, 10:41 AM
funwithguitars8 funwithguitars8 is offline
Question Digi003 Host light OFF
Hi there,
First time poster, so bear with me.
I am running a Mac Pro with ProTools LE 8.0.3 and a Digi003
My Digi003 has been giving me the following issues.
When I launch ProTools, the HOST or 1394 light turns on properly. However after playing any session for a few seconds I recieve one of several error messages - usually relating to 'invalid clock source' or '-6079 Lost communication with audio interface'. I have also had times where the HOST light blinks every few seconds.
I've searched the DUC far and wide, my issue is similar to this post: http://duc.digidesign.com/showthread...n+lost+contact
..however I still haven't found the solution.
I've tried suggestions from different DUC threads such as reinstalling ProTools, trashing preferences, swapping with a new firewire cable, different firewire cable arrangements, etc. Should I try resetting the firmware on the 003, or is that unrelated?
I contacted a local Digi Authorized Repair Center and the repair man thought the 003 may need a replaced motherboard (not the exact term he used), or possibly a new firewire port. Do you agree, does this sound like the a hardware issue?
Any help would be greatly appreciated! I've exhausted my limited knowledge of Digi troubleshooting, and am hoping I can get this issue resolved without spending money on repairs that I don't have! Thanks in advance.
Old 10-28-2010, 10:55 AM
Dogcode Dogcode is offline
Default Re: Digi003 Host light OFF
I have a Mac Pro Quad 2.66 with 003 Rack. I was having the same issues. I found that when I started using the Firewire port on the front of the Mac Pro, my "losing connection with audio interface" went away. I think it must be an issue with the firewire buss on the Mac Pro.
dog
PT 9
Control 24
003 Rack
Mac Pro 2.66 Quad
Adam A7
Waves Gold, VSeries
Pultec Bundle
URS, McDSP
Old 10-28-2010, 11:00 AM
Originally Posted by Dogcode View Post
I have a Mac Pro Quad 2.66 with 003 Rack. I was having the same issues. I found that when I started using the Firewire port on the front of the Mac Pro, my "losing connection with audio interface" went away. I think it must be an issue with the firewire buss is on the Mac Pro.
dog
Thanks for the quick reply Dog.
I will try this and post my results. Knock on wood that it is that simple!
Old 10-28-2010, 01:07 PM
Question Re: Digi003 Host light OFF
Unfortunately switching to the front FireWire port on the Mac Pro didn't solve the issue. I also got a new error message this time:
"A FireWire bus reset was detected. Please check FireWire cables and power to FireWire cables. -6090"
Mac Pro Quad Core
ProTools LE 8.0.3
Digi003
M-Audio Octane
JBL LSR4328
"God gave rock n roll to you."
Old 10-28-2010, 01:20 PM
Did you HOT Swap???....You should power down the mac and 003 before switching. Try powering both units down. Then turn on 003. Boot up Mac with the Firewire cable in the front port. Maybe even try a different or new Firewire cable. Post back your results.
dog
PT 9
Control 24
003 Rack
Mac Pro 2.66 Quad
Adam A7
Waves Gold, VSeries
Pultec Bundle
URS, McDSP
Old 10-28-2010, 01:42 PM
dog
I powered down the 003 but not the Mac Pro. Is that considered a HOT swap? I've read some horror stories about frying parts by doing so today. It's possible I did a HOT swap in the past that resulted in this problem, as I did not know what HOT swapping even meant until I started researching the problem today.
I powered down both units just now as you advised to no avail. Still got a -6097 error followed by the HOST light turning off.
*Also, I have tried three different working FireWire cables.
Mac Pro Quad Core
ProTools LE 8.0.3
Digi003
M-Audio Octane
JBL LSR4328
Old 10-28-2010, 04:19 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
I don't know if this will help. Turn everything off. Unplug everything from computer. Unplug computer from wall. Wait about fifteen seconds and plug computer back in. Boot computer back up. Plug in one at a time. If you have an external drive that's firewire then plug that into the port you were having problems with. See if that helps. I don't know if I helped at all or just got you more frustrated.
Old 10-28-2010, 05:46 PM
Tried it just for kicks. No dice.
Mac Pro Quad Core
ProTools LE 8.0.3
Digi003
M-Audio Octane
JBL LSR4328
Old 10-28-2010, 06:31 PM
What order are you running your firewire devices....Ive got mine Mac front port to 003> Mac rear port to drive........not the way they say to run it but it stopped my issues..
dog
PT 9
Control 24
003 Rack
Mac Pro 2.66 Quad
Adam A7
Waves Gold, VSeries
Pultec Bundle
URS, McDSP
Old 10-28-2010, 06:45 PM
Which version of OSX are you running with 8.0.3?
003 not outputting audio in PT9/host light out Revolver73 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-26-2011 10:15 AM
003 HOST 1394 Light Mryan1023 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-15-2011 05:01 PM
003 rack is not connecting. Blinking green light. no HOST 1394 light. ccgascity1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-14-2011 12:41 PM
003 Rack Host light doesn't light...pt crash Kourquie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-03-2010 09:07 AM
003 rack Host light blinking - HELP! rockwell81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-20-2010 07:53 PM
