#21
Re: Lightbridge Discontinued!
Also recently discontinued - I have one - works great.
#22
With PT9?
#23
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
#24
Out of curiosity, I could probably recall if you can give me the exact model of your Macbook. If you click on the Apple logo in the top left corner... then About This Mac > More Info... the very first thing you should see is hardware overview. The Model Identifier is all I need. For example: "MacbookPro3,1" I don't think any model of Macbook Pro was ever capped at 2GB. Apple spec usually said 4GB max, but I found out about 8 months ago that a lot of the older generation Macbook Pros will actually cap out at 6GB, and some of them 8GB. Can be a bit experimental with the 6GB, because you have to use a 2GB and a 4GB DIMM, but mine does it with no issues whatsoever.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
#25
#26
It looks like yours is too old to bump to even 4GB... but, of course it goes higher than Apple's spec max. You can put up to 3GB in that model. I believe you can buy kits directly from OWC for that.
#27
#28
#29
Simply do a partial DVERB test (minus the DVERBS ...If it will record 32 tracks of sine wave it will record 32 tracks of audio..... Chances are good that you can record 32 tracks to one FW or eSATA drive since its not dealing with edits. Try it for the amount of time you expect to record. If you don't encounter any issues try it at twice the sample rate. If thats good you should be just fine. If not split it across 2 drives.
#30
The 2,1 was the first to unofficially support 3GB. The 3,1 (mine) was the first to support 6GB, and was of the last generation of 15" with EC34. Most early unibody models (4,x) also supported 6. Pretty well everything after that will unofficially and officially support 8GB.
003 Discontinued? | bootc | Pro Tools 10 | 58 | 12-05-2011 06:15 PM |
Is 003 really discontinued? | ripekeai | Pro Tools 9 | 15 | 03-29-2011 06:05 PM |
001 DISCONTINUED. | jeml | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-21-2004 08:24 PM |
discontinued 001? on a G5? | rgriff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-27-2003 03:20 PM |
001 being discontinued??? | fabpab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-10-2002 04:18 AM |
