Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 05-19-2020, 12:55 AM
oxband oxband is offline
Default How can I speed up play back on a Mac?
I'm using PT 2020.3 on a MBP. I have to listen to lots of interviews to find good moments, so I want to listen at a faster speed. I cannot figure this out. Is there a way?
I've read about Shuttle Lock but perhaps thats only be a detail in early PT versions because when I search the Avid online info, there's nothing in there about it. Thanks!
Old 05-19-2020, 01:04 AM
Top Jimmy's Avatar
Default Re: How can I speed up play back on a Mac?
You’d need a numeric keypad. Look up shuttle numeric keypad mode in the manual.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 05-19-2020, 11:45 AM
While it may be possible to do it with the Fn key modifier, I also recommend adding either a full-sized keyboard, or a numeric add-on.
Old 05-20-2020, 05:15 AM
midnightrambler midnightrambler is offline
I don't think this numeric pad solution is much of a help really, as the next playback speed is x2 which is pretty "chipmunky".
Anyway this is what I would do in your position - enable elastic "varispeed", set track to "ticks", and then set the tempo to something faster like x1.5 (e.g. a tempo of 120 becomes 180) so that you can still hear what the interviewee is saying but isn't completely chipmunked, highlight the good bits, then switch the elastic back off and "revert". You could probably use polyphonic as well if you prefer but for me using varispeed feels a bit more old school.
It'd be really nice to have a varispeed control on the transport window though wouldn't it. Reckon I could get mixes done in half the time
Old 05-20-2020, 08:47 AM
_JJ_ _JJ_ is offline
"QuickTime Player" can play audio at double (or even 5x) speed if that would work. I'd also recommend Roni Music's "Amazing Slow Downer" which is handy for changing speed and/or pitch.
speed play back issues flautista Pro Tools 12 2 10-26-2017 09:54 AM
How to play back faster than 1X speed? wevets Getting Started 4 02-20-2016 03:29 PM
How do I adjust play back speed? SWBoatman25 Getting Started 1 03-06-2015 10:59 PM
PT sessions sometimes play back at slow speed moogsy Pro Tools TDM Systems (Mac) 0 03-14-2006 04:58 PM
why does song play back at faster speed? meeksmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-29-2003 01:15 PM
