Old 07-12-2012, 06:25 AM
phatbeatstudio phatbeatstudio is offline
Default Every time I adjust volume it zeros to the bottom
I cannot adjust the volume of a bunch of grouped tracks.
I move the fader then it just zeros back to the bottom like if it were automated.
I then tried to cut all automation on those tracks no luck so I then individually tried to cut the tracks then cut all automation on them individually but no go.
Im stumped. cutting automation should have done it but it didn't what am I missing.
The tracks will stay where I want if I turn it from read to off so its got to be an automation problem I assume.
Iv tried everything I can think of . I even deleted the group then repeated it all again.
This has to be something in automation what am I doing wrong
Old 07-12-2012, 08:53 AM
steviemac74 steviemac74 is offline
Default Re: Every time I adjust volume it zeros to the bottom
It sure does sound like an automation problem. If your group is set for 'mix & edit,' keep the group active then go to the edit window and check volume automation on the tracks that are highlighted. I don't see it being much more than that!
Apple Mac PPC G5 2.5Ghz Quad Core, Protools HD3, Magma 13 slot Expansion Chassis, Digidesign 192 I/O, Digidesign Command|8, Ableton Live 8, Mackie HR624's
What we provide is an atmosphere... of orchestrated pulse which works on people in a subliminal way. Under its influence I've seen shy debs and severe dowagers kick off their shoes and raise some wholesome hell..
Old 07-12-2012, 09:11 AM
It still happens even after I deleted the group.
I am going to try again but I have a few times already.
Old 07-12-2012, 09:53 AM
studiojimi's Avatar
studiojimi studiojimi is offline
run the utility and if that doesn't work
import the whole thing into a fresh empty session
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Can't adjust volume of OS X, only the output volume of ER JustGoWithIt Eleven Rack 8 09-26-2011 01:32 PM
Adjust volume across ALL tracks? Michael P. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-06-2009 03:56 PM
Is it possible to adjust the input volume ? andots 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-27-2005 06:10 PM
Can't adjust volume while recording... Bodhisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-24-2003 12:01 AM
Volume adjust? dannepop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-13-2001 07:40 AM
