Multiple Audio Suite Window's
Sorry if this question has been answered before....
Is there a way to have multiple audio suite windows open? I wish to use "tune" with the waves tuner and also use the "gain" plugin too. I hate having to reopen each plugin window each time i switch! |
Re: Multiple Audio Suite Window's
on the plug in window to the right upper corner is a bullseye icon in red and white. Click it and it keep the plug in window open
Digidesign 003R+PT 2020.12.0, Gigabyte GA-Z97X, CPU INTEL i7-4790 4.0Ghz, CORSAIR DOMINATOR 16GB; ATI Radeon™ HD 5450 PCIe Multiple WD Caviar Black 2Tb Spinner Drives; 1 PPA 80GB 1394 Firewire Oxford 911 PYRO PCI64R2 3 Port Firewire Card (PCIe) Antec 300 case. PSU 600W, Windows 10 Home. |
Is that a feature I missed on PT8?
I meant dual windows from the Audio suite menu not inserts...... I know how to have multiple plugins open via the target function. |
Chris
Ah.... NO... I don't want to do 2 proceses at the same time... I want 2 RTAS windows open at the same time, so as to do 2 different audio suite processes..... one after the other on multiple pieces of audio, without having to re open said RTAS window every time, I either tune... or gain a region!
A big Computer, with a BIG heart! |
AS = AudioSuite - no realtime processing. RTAS = Real Time AudioSuite - realtime processing. I assume you want to process a file or several files with 2 different AudioSuite processes, one after another, yes? You can automate such a sequence with QuicKeys or AppleScript. There is currently no way to do this without additional programming tools and/or skills. Oliver |
I agree it is a pain, not being able to have two Audiosuite plug-ins open, and having to mouse through the whole list to find the relevant one each time quickly becomes tedious.
What I do, which may help you, is set up two "window configurations". Have one plug-in open, go to Window->"New Configuration" and save it as a Window Layout, then do the same with the other plug-in, then you can recall the plug-in window easily by typing ".1*" (or ".2*" etc) on the numeric keypad. This can save quite a bit of time. |
Yes but the way audiosuite works is; when you select a region the audiosuite plugin is immediately referencing to it on your hard drive! and in many cases also analyzing it!! so it wouldn't be possible to have 2 audiosuite plugs to be referencing and analyzing the same piece of audio. Now maybe if the audiosuite menu could stay open? then we could quickly select the next one we want. Chris
You can Apple select an AS plug and it will appear in the top level of the AS menu. You can have all your most used AS plugs there and it makes selecting them considerably quicker ...
Multiple Audio Suite windows? | idris | Pro Tools TDM Systems (Mac) | 14 | 04-15-2017 08:14 PM |
multiple audio suite effects | bbbkink | Windows | 8 | 02-05-2013 05:34 PM |
Multiple audio suite plug ins Open. | kd_special | Pro Tools 9 | 7 | 12-18-2010 11:54 AM |
A Window's Q | flea03 | Pro Tools M-Powered (Win) | 1 | 03-16-2006 02:33 PM |
iTunes vs PT's import audio window's player | cc1 | Pro Tools TDM Systems (Mac) | 1 | 04-10-2005 08:33 PM |
