Old 05-28-2020, 04:00 AM
Default Playback momentarily stops when editing within playlists
Does this not bug the hell out of anyone else? It never used to do this. I honestly think I would prefer to have the old system back. It feels like such a basic thing, to be able to move clips about without playback stopping, that I can't believe anyone at AVID thinks this a compromise worth having in order to have whatever new fancy playlist functions we now have. It's so, so horrible. How on earth are you supposed to edit anything together on the fly with this spluttering and stopping? You can't even move from a track in "playlist" view onto another track without it stopping, even if the clip is on the "top" playlist. You can't even delete clips without it pausing! Jeez.
It's so bad. Did I tell you how bad I think it is? Bad, that's how bad.
Old 05-28-2020, 04:48 AM
Wolfgang Eller Wolfgang Eller is offline
Default Re: Playback momentarily stops when editing within playlists
I removed some clips with cmd+B and it worked.
www.srs-mastering.de
Mac Pro 6.1-8core, OS 10.15, PT2020, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 05-28-2020, 06:43 AM
Yeah, on the top playlist. Now try doing it on one of the other lanes.
Old 05-28-2020, 09:27 AM
Could you exactly explain what you are doing?
I really don't get it.
Maybe I never worked the way you do.
Old 05-28-2020, 10:11 AM
It look like it's another one of those intermittent bugs, I can't get it to do with it with just one track playing. Let me get back to you with a recipe...
Old 05-28-2020, 10:28 AM
mtmusic mtmusic is offline
Yep, I've experienced this issue and I hate it. It is indeed bad
The basic formula is, have a track or groups of tracks with alternate playlists. Go to playlist view. While playing back, make any kind of edit to an alternate playlist (i.e, cut a clip, move the clip, delete the clip, etc). The playlist that you're editing doesn't have to be solo'ed for it to momentarily stop
I think this is some kind of buffering issue? I seem to only be able to recreate it when there are a lot of playlists, some plugins on the track, that sorta thing. Still super annoying though, and didn't used to be an issue. I think it started to happen when they introduced the target playlist features
Pro Tools 2020.3
Mojave 10.14.6
Mac Pro 2013, 3.5 GHz 6-Core, 32GB RAM
Antelope Orion
Old 05-28-2020, 11:54 AM
seanmccoy seanmccoy is offline
He's talking about playback being momentarily interrupted when making any change of any kind to a clip on an underlying playlist. I've experienced this off and on through quite a number of updates over several years, so it's not new. It only happens in certain projects, and to this day I've never been able to identify a common factor. It is most annoying when it happens.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2020.5, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2019.10
Playback stops when editing in playlist view garderobamusic Pro Tools 2019 7 02-18-2020 09:52 PM
MIDI Thru stops working after sequence playback stops kelcarpenter MIDI 20 03-16-2016 11:43 AM
7.4 stops playback momentarily when highlighting an area Stephen Bond Pro Tools M-Powered (Mac) 2 11-09-2007 04:01 PM
editing and playlists toddro Pro Tools TDM Systems (Mac) 4 07-29-2003 02:37 PM
Editing all playlists brandono Tips & Tricks 0 11-24-1999 11:47 PM
