  #431
Old 08-24-2013, 09:34 AM
SHIRK SHIRK is offline
Default Re: -9171 and -9172 errors with Pro Tools HD 10.3 on HDX
Originally Posted by Neale Eckstein View Post
I'm looking at that slot 4 option. Seems like its going to block the fan with the hard drives. Why not slot 3?
Neale, did you try moving your HDX card to slot 4 (or even slot 3)? Curious to hear if this made any difference for you with regards to -9171 and -9172's. Thanks.
SHIRK
www.shirkmusic.com
www.hearya.com
MacPro 12core 2.66Gh Westmere
OSX v10.7.5
20GB RAM
1x HDX
2x HD i/o 16x16, 1x Digi192 8in/16out
PT HD v10.3.7
  #432
Old 08-24-2013, 12:22 PM
Neale Eckstein's Avatar
Neale Eckstein Neale Eckstein is offline
I put it in slot 3. So far no errors, but I haven't really tested it long enough. Also, I'm using several beta plug-ins in 11 from Ivory, Omnisphere, and Soundtoys.
  #433
Old 08-24-2013, 12:46 PM
GuyPicks GuyPicks is offline
Neale,
Keep us posted.
I'm having the same problems.
System 1---------------------System 2
MacPro 5,1---------------------------Windows 10
2-CPUs-------------------------------i7-CPU
OS X 10.14--------------------------Pro Tools 2019.5 HD
PreSonus 1824c --------------------HDX / 192 Analog
Fader Port---------------------------2-24" monitors
NI S61mkII--------------------------32GB Ram
64GB Ram---------------------------4 internal Drives
5-Glyph Rack Drives----------------Presonus 192 Mobile
2-24" Monitors----------------------Nektar Impact LX88+
Glyph Raid 4
  #434
Old 08-24-2013, 02:03 PM
bortraws bortraws is offline
I moved my HD Native Card to slot 3 but unfortunately it made no difference to the amount of errors that I encountered.
Bortraws
  #435
Old 08-25-2013, 02:21 AM
Problem is that I also believe my harddrive in bay 4 (right above PCIe slot 4) doesn't get enough cooling when the HD Native card is in there.
I have a Radeon HD 5770 graphics card with 3 monitors connected and that generates a lot of heat. Already 2 harddisks in bay 4 have basically died giving bad blocks with the HD Native card in slot 4 blocking cooling to the hard drive.
Slot 3 might be a better option but I haven't tried it yet. Slot 4 doesn't make a difference to the errors though so I'm afraid that moving the card doesn't really help.
Bortraws
  #436
Old 09-13-2013, 03:58 PM
Hanswurstlsepp Hanswurstlsepp is offline
I'm on HDX since bout a week now and I'm getting occasional -9171 errors, too.
No big deal so far - after hitting ok PT 10.3.7 works again ... til all of the sudden *somewhen later* same error will happen again.
Tried all kind of playback engine settings combinations - but no luck so far.
It also happened that when I load a new project in, PT won't go into plb mode when I press play and a couple of seconds later the error -9171 pops up.
If this has happened, I always had to quit PT10.3.7 and restart it and reload the session which then will finally play.
Also sometimes I'm getting this. But I just clicked ok and everything worked fine.
All those errors never happened with my HD6 in MagmaChassis rig.
... still investigating and watching this thread ... but I confess, I haven't read all 48 pages ...
Cheers, STeff
MacPro5,1 , 32 Gig Ram, 2xATI Radeon HD 5770, OSX10.13.2  Pro Tools|HDX Ultimate 2018.4.0  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
  #437
Old 09-16-2013, 01:23 AM
Boe Larsen Boe Larsen is offline
Hm, Hans... Join the club. I've still got them too.
Boe Larsen
Producer
www.millfactory.dk
  #438
Old 09-16-2013, 01:33 AM
Hi Boe,
thx for the warm welcome
I worked wit PT11 during the last 2 days.
Much better, less errors (was on 128 samples), lower latency, snappier etc
Maybe PT10 isn't made for HDX
Also I doubt that Avid will use manpower to investigate any further into PT10.
Cheers, STeff
  #439
Old 09-16-2013, 01:34 AM
10.3.7 also hasn't fixed the problem for me running it with an HD native system and an OMNI.
Bortraws
  #440
Old 09-16-2013, 01:55 AM
Originally Posted by Hanswurstlsepp View Post
Hi Boe,
My experience exactly Hans
Boe Larsen
Producer
www.millfactory.dk
Pro Tools 10.3 9171 and 9172 Errors Tops3b Pro Tools HDX & HD Native Systems (Mac) 20 07-14-2013 03:11 PM
-9171 and -9172 errors constant...Sandra attached wrachilla Windows 12 05-09-2013 09:19 AM
UAD triggering 9171, 9172 errors? xq3js macOS 7 03-22-2013 11:47 PM
Dae errors -9171 after installing 10.3.3 TCM Pro Tools HDX & HD Native Systems (Win) 3 02-06-2013 10:18 AM
10.3.3 Major Fail....9171, 9172 and 9129 Errors Tops3b Pro Tools HDX & HD Native Systems (Mac) 3 12-21-2012 07:21 PM
