Old 09-03-2018, 10:37 AM
musicmaker1 musicmaker1 is offline
Default monitor balance off?
I keep losing left monitor volume, what could it be? It doesn't do it all the time
Old 09-03-2018, 11:11 AM
Southsidemusic's Avatar
Default Re: monitor balance off?
Welcome to the Community
please start here:
http://duc.avid.com/showthread.php?t=300050
As much info as possible and how things are connected in the setup.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-03-2018, 01:03 PM
arche3's Avatar
arche3 arche3 is offline
Probably a cable connection.
Old 09-03-2018, 01:37 PM
zedhed's Avatar
zedhed zedhed is offline
The first and easiest thing to check is cables/plugs. I have a cable that doesn't lock into the speaker socket properly and has to be regularly pushed in. Check plug 'snaps' into position.
Swap the Left/right cables and see if the other speaker behaves poorly. If it does, it's a cable problem & if it doesn't it's most likely the speaker (dry solder joint maybe).
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 09-03-2018, 02:33 PM
arche3's Avatar
Also could be aliens.
Old 09-03-2018, 02:39 PM
zedhed's Avatar
Yep, that's the American way now....blame the aliens
HD 96I/O
PT 10 & Hybrid 3 L-R balance colinmansfield Pro Tools 10 2 09-09-2017 11:05 AM
Output monitor volume balance problem upstate Digidesign Hardware & Software 2 03-18-2014 12:18 PM
Reason Balance himynameisdustin macOS 0 12-20-2012 08:59 AM
rig balance issues Idisagree Eleven Rack 2 03-23-2011 08:46 PM
Balance/Pan problem John Barnes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-04-2007 10:05 AM
