Old 01-16-2019, 02:46 AM
belasoul belasoul is offline
Default Video convert ratio
I received a h264 from the editor and used mpeg streamclip to change to DNxHD 36 8bit. Both Videos are 2048 x 1024. But the h264 shows extra black bars / letterbox in the PT Video Window and unfortunetly the DNxHD has no black bars and everything is stretched up/downside. Can you tell what i possibly miss while converting the video in Streamclip?
MacOs 10.13.6, RME Fireface UC / UAD Apollo, PT Ultimate 2018.12
Mac Pro 6.1/12-core
Old 01-16-2019, 03:56 AM
henningaround henningaround is offline
Default Re: Video convert ratio
Hi!
Assuming that you're using video hardware: Usually Pro Tools puts out video in broadcasts formats. If your video doesn't have a broadcast format, PT adds the letterbox. MPEG streamclip automatically scales it to a broadcast format. Try adding the letterbox yourself in MPEG streamclip to keep original aspect ratio. This peace of software is a little bit outdated, but it's possible :)
Regards
henning
Old 01-16-2019, 03:11 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Export them as 1920x1080 and add letterbox.
Vedat
Check out WaveRider + Defaulter:
QuietArt.co.nz
Catchin' SYNC app
Old 01-17-2019, 01:50 AM
Thank you! Do you know how to determine the amount of letterbox from the source h264 and to translate that to the Streamclip settings?
Mac Pro 6.1/12-core
Old 01-17-2019, 02:32 AM
I think MPEG Streamclip adds the correct amount of letterbox if you calculate the zoom ratio correctly. Should be around 88% in this case?
Old 01-17-2019, 01:18 PM
I generated a DNxHD36 with 88% Zoom. The result is closer to the original h264 but there are additional black bars at the sides from zooming. Do you know how to add the exact same letterbox like in the source video?
Mac Pro 6.1/12-core
Old 01-17-2019, 11:25 PM
You have to calculate the right amount of zoom. I was just guessing 88% :)
Old 01-21-2019, 11:30 AM
nucelar's Avatar
nucelar nucelar is offline
With Mpeg streamclip your best bet is to trial and error the zoom value. We don't know the exact amount of letterbox so how should we know... :) For testing, apart from the small preview window.. : choose a short snippet with in and out point for export testing. when happy, select all and export the whole.
Old 01-22-2019, 09:03 AM
Kuba Pietrzak Kuba Pietrzak is offline
And this is why I like (and still use) Quick Time Pro.
You just tick "preserve aspect ratio" setting and you're done.
Whatever I receive (cinemascope, insta 1:1, etc.) I convert them to 16:9 with QT without any problem (and math)
Kuba
HTML code is On
Different Aspect-Ratio of video in the same track critictalk Tips & Tricks 0 06-03-2014 08:34 AM
Compression Ratio when Capturing Video in PT PostMorgan Post - Surround - Video 9 04-19-2011 08:28 AM
Video Aspect Ratio Question Peter Miller Post - Surround - Video 5 10-02-2009 02:30 AM
Video Aspect Ratio Question Peter Miller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-25-2009 07:08 PM
Video aspect-ratio. lode Post - Surround - Video 10 02-09-2007 06:39 PM
