Trim vs Volume
Could someone quickly explain to me the differences between volume and trim in Pro Tools? I'm not talking about the Trim automation mode since I'm not on HD and I don't have CPTK, I'm talking about the plugin.
What's the difference between having my volume at -6db and no trim plugin, and having my volume at 0db and a trim plugin at -6db? Thanks.
Lenovo T61 T9300 Core 2 Duo 2.5ghz 4GB DDR2 2 1TB FreeAgent Xtreme External Drives SIIG FireWire Express Card Windows 7 Ultimate X64 Pro Tools 8.0.4 LE Digi003 Rack || PreSonus D8 || ART MPA Gold || ART PRO VLA II || Ensoniq DP/2 M-Audio Axiom 49 || Behringer BCF2000 Yamaha HS50Ms Bands: Captain Starr || stereoINs Drums: 1 || 2 || 3 Guitars: 1 || 2 || 3 |
Re: Trim vs Volume
To add to this, what would be the difference in using a trim plugin vs say using only the fader on a plugin like SSL Channel?
Re: Trim vs Volume
No difference you can hear. But I often use the trim plugin to temporarily change something in a mix, so I can lose the plugin and restore the mix instantly.
Re: Trim vs Volume
Gain is gain. Just a workflow choice. To expand on albee's tip, I use the Trim plug when I have volume automation written to a track, and need to adjust it by a constant amount. Since your eyes often skew your audio perception, I close my eyes and adjust the volume with the Trim plug until I'm confident I've locked it in. Then I open them, trim the volume automation by the amount shown on the Trim plug readout, and ditch the plug.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Re: Trim vs Volume
The difference is that trim happens before your inserts and volume happens after.
Re: Trim vs Volume
Great point. It can be anywhere in your inserts, of course. If it's in the first slot, it obviously comes before. If it's in the last slot, there's no difference. In between, well, you get idea.
Re: Trim vs Volume
ok I planned on putting it in the last slot of my inserts. I ask because I have a Behringer BCF2000 control surface with non-touch sensitive faders. I find myself using volume automation early on in the mixing process, making the faders on my control surface entirely useless. I was thinking of creating a session template with all audio tracks having the Trim plugin in the last slot and having it automated. I'd have to get into the habit of working this way, but I'd do all my normal volume automation on the trim plugin instead, thus leaving the actual volume automation lane untouched, so I can use the faders on my control surface again. Does this seem like a reasonable solution?
Re: Trim vs Volume
Great idea! That's using your tools.
Re: Trim vs Volume
Oh ya. When I posted that I thought we were talking about the audiosuite version.
Re: Trim vs Volume
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
PTX 10.1.1 Volume Trim Bug? | Cryos | macOS | 6 | 03-26-2012 09:40 PM |
trim volume pt 9 le? | papitopinillo | Pro Tools 9 | 14 | 08-25-2011 01:29 PM |
volume trim in PT LE | golafs | Tips & Tricks | 9 | 10-31-2008 04:43 AM |
7.2 Volume Trim | Ken P | Post - Surround - Video | 9 | 09-21-2006 10:54 AM |
volume trim | oilbedamned | Pro Tools TDM Systems (Mac) | 17 | 04-27-2006 05:33 AM |
