Old 07-24-2019, 09:19 PM
djmichaelwenz djmichaelwenz is offline
Default MIO Console Stops working Eucon 19.5 and 19.51
Hi, so I mainly use my Artist Mix for controlling Metric Halo's MIO console. It is a fantastic way to control all my Ins and outs as I have multiple converters. Works absolutely wonderful I might add. So my artist mix is used as a way to control whatever I want to monitor. It is the software that is the brains behind my soundcard.
In version 18.3 My Artist Mix works well with the latest version of MIO console. Since 19.5 and 19.51 there has been no connection to MIO Console with my Artist Mix. Not a big deal. I rolled it back to 18.3 and the controller went back to working just fine and I didn't think to even check to update it as it did what it needed to.
Now here is my problem... I am doing a very large video project that spans three DVD's and 15 hours in Final Cut Pro. I created a great Eucon key command using my iPad to create DVD markers with one tap. I have to create about 250 DVD markers so this is the best time saver I had found. It is the only thing I use my iPad for.
My iPad must have updated PT control as I had gotten a warning on my mac that "PT Control and Eucon were Incompatible". So I went ahead and installed 19.51 and the iPad connected as suspected but MIO Console stops working.
I have unchecked and re-checked to use Eucon in MIO Console in the MIO prefs and it does not connect. As soon as I roll back to Eucon 18.3 I will get my monitor controller back.
So am I to have to uninstall and reinstall every time I have to marker a DVD project????
System: MacPro 5,1 MacOs 10.14.6 Mojave, RX-580
www.WenzMastering.com
Old 07-24-2019, 11:45 PM
Default Re: MIO Console Stops working Eucon 19.5 and 19.51
After markering my DVD projects I Rolled it back to 18.3 and came right back to working. Does anyone know if MIO console is not supported in 19.+ ??
FRUSTRATING
Old 07-25-2019, 12:04 AM
BScout BScout is offline
Can’t remember which Eucontrol versions had firmware updates, but have you checked with the latest Eucontrol installed if your Mix firmware needs updating?
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, Fire HD10 + Max11, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.5RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 07-25-2019, 10:38 AM
I will check tonight! Thanks for the tip!
Old 07-25-2019, 02:43 PM
Looks like mine is up to date... I rolled back to 18.3 and all is good. (IPAD NOT WORKING STILL)
Here was the prompt from Eucontrol
Change firmware on the following unit?
MC Mix
current version: 1.5.6.0
downgrade to 1.5.4.0
Click 'Update Firmware' to update the unit. Status messages are displayed as the unit is updated. DO NOT POWER OFF UNIT unless instructed to do so.
Old 07-29-2019, 05:41 PM
Does anyone know if MIO console support has been dropped? This is clearly not working.
Old 07-29-2019, 11:33 PM
bartosz idzi bartosz idzi is offline
djmichaelwenz,
Did you contact Metric Halo about this? They should know. And the support is great.
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11
Old 08-05-2019, 07:11 PM
Peter Baird's Avatar
Peter Baird Peter Baird is offline
There’s a change between 18 and 19 that seems to break the Euphonix MIDI widget. It made my Artist Mix panels dead with respect to Studio One (which uses the Mackie protocol). Rolled back to 18.3, re-installed a few times, back in business.
Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk
Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9
www.remotewest.com
@RemoteWest
Old 10-02-2019, 05:23 PM
Such a bummer, I am going to have to do this again because the iPad app won't work. Does anyone know if you can install two versions perhaps?
Old 10-03-2019, 07:10 AM
EddieJones's Avatar
Firmware has nothing to do with this. Theres another thread on here about how to get Mackie control working again in 19.9. We are aware of the issue but its proving hard to fix in software.
MIDI Thru stops working after sequence playback stops kelcarpenter MIDI 20 03-16-2016 11:43 AM
Softsynth stops working Dave Modisette Pro Tools 11 8 02-16-2014 09:58 AM
Eucon On/off sends & EQIII band IN stops indicating. Audioartist Artist Series 3 09-09-2013 05:09 AM
Eucon Fader Unity Feature on S5 Fusion Console El_Palido System 5 1 05-24-2012 10:32 PM
7.2 -- what stops working? brucecoughlin Pro Tools TDM Systems (Mac) 2 08-29-2006 12:05 PM
