Old 01-29-2015, 10:55 AM
gfsarge gfsarge is offline
Default external clock source / transport stop
Does Anyone Know?,
I am having a problem with the clock sync system in my DAW. When playing or recording in pro tools at 96k the transport will suddenly stop and a pop up message will read (" The transport was stopped due to a problem with the external clock source. Please check the connections and verify that the external device is operating correctly, or select a different clock source.")
I'm using ann Eleven Rack as the main interface, with an Apogee Rosetta 200 as the input into the E-rack through AES I/O at 96k. The "wide" and "narrow" Lock indicator lights on the front of the Apogee are both lit and steady. I use the S/PDIF I/O on the Apogee to connect to a Tascam recorder.
In the "Hardware Setup" window in Pro tools, the only peripheral listed is the E-rack with clock source set to AES/EBU and sample rate at 96k. I have proper AES cables between the E-rack and Apogee and usb from E-rack to computer using Pro Tools 9.0.5 The DAW doesn't seem to have any problem with 44.1k, but I would like to continue to use 96k sample rate.
Anyone know what is going on ? What is stopping the transport ?
Thanks In Avance For Any
Help You Can Offer,
Greg
Old 01-31-2015, 08:20 AM
Default Re: external clock source / transport stop
Disconnect the SPDIF connection and see if it still does it. If that's not it, could it be a dirty or bad connection with the AES cable?
[IMG] code is Off
External word clock source for 192? jrmintz Pro Tools TDM Systems (Mac) 5 04-08-2010 08:35 PM
External clock source invalid Fergus Kelly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-22-2006 01:39 PM
External Clock Source for Digi 002 alejo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-14-2005 11:14 AM
External Clock Source 002 foisyt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-12-2005 09:54 AM
can u stop midi clock when transport is stopped? Namaste Pro Tools TDM Systems (Mac) 0 10-31-2003 02:36 PM
