Old 09-26-2011, 07:53 PM
ashwalk ashwalk is offline
Default Plugins disappear from list after a while, re-appear when quit/re-open
This is a very unusual issue.
I open a new session, open some plugins as inserts, everything working normally. The randomly, after a while, if I try to insert a new plugin, there`s nothing on the list, except the separator lines. The already open plugins, although working, appear on the list as "n/a".
It also happens when I open an old session.
If I look at the plugins folder, everything's in order.
Then I quit Pro Tools, re-open it, and everything's back to normal. But this happens all the time!
I'm running a Mac Pro with OSX 10.6.8
Any clues?
Old 09-27-2011, 01:48 AM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Plugins disappear from list after a while, re-appear when quit/re-open
Have all your plugins been updated for compatibility with your OS & version of Pro Tools?
Otherwise try Trashing Preferences.
http://www.youtube.com/watch?v=Mj2fJHOz8GA
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 09-30-2011, 03:44 PM
EMGactive EMGactive is offline
I am having the EXACT same issue. I trashed the preferences and this did not solve the problem. Any other ideas?
I have also tried re-installing PT. Still didn't do anything...
I am running Pro Tools 9 on Mac OS 10.6.8.
Old 10-04-2011, 05:01 PM
Thanks for the answers, guys. I thought I would receive an e-mail if someone answered my thread. I'm such a noob.
My plugins are latest, and trashing preferences didn't work for me either.
EMGactive, is your machine an OSX86? I ran into a guy that had that problem on an OSX86, Intel.
Hoping someone else had this issue...
Old 10-05-2011, 12:31 PM
Fomin Fomin is offline
ashwalk - are you using a legit version of Pro Tools ? I'm asking this because the problem you're experiencing is a well known issue with cracked Pro Tools 9 . I own HD 9 license and never heard about this problem with a legit version .
Old 10-06-2011, 09:55 PM
Well, formin, yes, legit version.
And where did you know about this problem on cracked versions of Pro Tools?
If they had this problem too, it would be nice to know if they found what's causing it, since it's clearly not a cracked-version-only problem.
Old 10-09-2011, 09:16 AM
mrjohn mrjohn is offline
I had this happen to me. Turns out the USB extension cable to my keyboard came loose, momentarily disconnecting my iLok which was plugged into the keyboard hub.
Mac Pro 2 x 2.8GHz Quad
OSX 10.10.5, PTHD 12.4.0
Old 10-26-2011, 02:51 PM
That makes sense, will czech that, thanks.
Old 02-13-2012, 12:32 PM
ScottRobinson ScottRobinson is offline
I'm having this same problem lately. anyone ever figure out a solution?
Old 03-17-2012, 07:38 PM
I have a usb midi keyboard that sometimes disconnect, but even with it unplugged the problem appears...
[IMG] code is Off
How did my plugins suddenly disappear? wfenlon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-27-2013 07:27 PM
sessions always open with mix window track list open jaglance Pro Tools TDM Systems (Mac) 2 08-03-2009 06:03 PM
003 R+: Quit PT, open CoreAudio Manager = no sound!! (><) SOLVED UltraNEO* 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-04-2009 11:05 AM
HELP!! Regions disappear from the region list kriskaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-27-2007 12:29 PM
Plugins missing in drop down list, but in plugins folder ?? mixingmadness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-12-2007 10:27 AM
