Old 01-13-2015, 02:41 PM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
Default Re: Can you use HD hardware with pt9
Originally Posted by RickoDean View Post
Actually when I registered my software, it was on the standard pro tools 9 with the digi 002r. I'm not sure if my registration would cover it or if I'll need a HD license. Fwiw, pt9 is on my ilok
You have been given the answer several times now.
You NEED a HD asset to use any Avid or Digi HD cards so you need to either buy a used HD license normally around 1200-1500 dollars or you can look for a CPTK and get the HD upgrade along with your PT9 asset.
Best
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 01-13-2015, 02:48 PM
RickoDean's Avatar
RickoDean RickoDean is offline
Hmmmmmm.. Only if I could get in touch with avid, smh. So far, I only see pt 8, 10 & 11hd licenses on eBay. I was thinking move forward & not back to 8. The pt 10&11hd licenses are way out of my budget, at least until tax time. All and all I surely appreciate your advice. Thanks
MacPro2,1 2x Intel Xeon 3GHz Quad Core, 32GB ram, 1GB Sapphire Radeon HD 5770, OSX 10.7.5 (Pro Tools 9.0.6 HD3), 96 i/o, 96i, sync i/o, midi i/o, BBE 442A, ARC MDC 2001, DOD SR831Qx, ART Pro MPA II (GE tube mod), Behringer Virtualizer Pro, 250GB Hard Drive (system)/ 250GB Hard Drive (recording) / 250GB Hard Drive (audio + sample bank), 250GB Hard Drive (Overflow), DigiDesign ProControl, Pro Control Fader Pack, Maschine MKII, Alesis QS6.1
Old 01-13-2015, 02:51 PM
RickoDean's Avatar
You NEED a HD asset to use any Avid or Digi HD cards so you need to either buy a used HD license normally around 1200-1500 dollars or you can look for a CPTK and get the HD upgrade along with T9 asset.
Best
Christopher
With all due respect Christopher, I have been chatting with one person, until you chimed in, I have been given an answer only once, not several... I get it, I UNDERSTAND now.
Thanks for your input
[IMG] code is Off
Unable to locate hardware. Make sure your hardware is connected and turned on. Click ohwhat2 Pro Tools 11 20 01-19-2015 11:47 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on ytass Pro Tools M-Powered (Win) 4 11-25-2009 12:49 PM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
unable to locate M-Audio hardware. Make sure your hardware is connected and turned on joskraus Pro Tools M-Powered (Win) 13 05-13-2009 09:05 AM
