Old 04-09-2021, 11:04 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Default Dolby Atmos Production Suite trial
Is the trial version of the Dolby Atmos Production Suite found here:
https://developer.dolby.com/forms/do...n-suite-trial/
The same as the one sold by Avid? That site says it's a 90 day trial, is that correct?. And is the trial limited in anyway?
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 04-10-2021, 02:34 PM
reichman's Avatar
reichman reichman is offline
Default Re: Dolby Atmos Production Suite trial
Yep, that's the same as the one sold in the Avid store. IIRC, there were no limitations during the demo. Check it out! But give yourself time if you're new to the workflow. There's a lot to learn.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 04-10-2021, 07:14 PM
JCBigler's Avatar
Great, so the trial doesn't do anything stupid like blasting white noise every 30 seconds? Or limiting how long each project can be?
Is it worth checking out even if you don't have all the surround speakers and can only use the binaural headphone rendering? (FWIW, I'm quite familiar with mixing live shows in immersive environments and using object based maxing having toured with L-ISA and used SpaceMap).
Justice C. Bigler
Old 04-10-2021, 08:14 PM
reichman's Avatar
With your experience, you'll feel right at home. The binaural headphone render alone is worth the price of admission. Absolutely worth anyone's time even if you don't have the speakers. It was years ago that I ran the DAPS trial, so my memory might be shaky, but I'm pretty sure it was fully-functional.
Inside DAPS, you can turn loudspeaker processing off, which will reduce CPU usage and also make the metering and monitoring more straight-forward when using headphones for binaural rendering alone. I recommend using the Dolby Audio Bridge, LTC (not MTC) timecode, and using an aggregate output device from DAPS (more info on that topic in the manual). Many preferences that are very important in binaural including near/mid/far object distances. Personally, I prefer the 7.1.4 loudspeaker experience, but the binaural experience is really good.
Nathaniel Reichman
Old 04-10-2021, 08:27 PM
JCBigler's Avatar
Sweet, thanks for the info. I have a symphony mix that I need to finish. But then I have a couple other projects in May that I want to try out with Atmos and then spend some time over the summer working with. I'm pretty sure that I'll just go ahead and buy it, but wanted to make sure that it would function and work the way I think it should first.
Will it run on a MacBook Pro?
Justice C. Bigler
Old 04-10-2021, 08:48 PM
reichman's Avatar
Yep, it will run on a MacBook Pro. Depending on the complexity of your mixes, you may find that it pushes the limit of your machine. But if you have the time to balance CPU power by freezing tracks in Pro Tools and/or doing a mix of online and offline re-renders, you should be ok. Alan Sallabank's series on Pro Tools Expert is a great resource for PT and DAPS. Be aware that there are really three levels of Atmos:
DAPS - single CPU system for making home theater and music mixes
DAMS - multi-CPU system for more elaborate home theater mixes with the renderer (DAMS) on a dedicated Mac or Windows machine
DA Cinema - high-end, lease-only multi-CPU system and Windows renderer for mixing films in Atmos.
Not to be discouraging, but I don't recommend releasing anything that you haven't had the chance to hear in 7.1.4. Before I upgraded my studio to 7.1.4, I worked on music mixes with DAPS and then took them to a better-equipped room to finish them. Last November, I connected TIDAL to my rig. AMAZING. There are some great Atmos albums out there.
Nathaniel Reichman
Old 04-10-2021, 09:22 PM
JCBigler's Avatar
DAMS - multi-CPU system for more elaborate home theater mixes with the renderer (DAMS) on a dedicated Windows machine
I've been trying to wrap my head around this one. It seems that to use this level, you have to buy the more expensive Mastering Suite and a dedicated computer from a certified builder. Is it not possible to put together your own rendering machine or use a spare PC that you already have?
Also, what kind of speakers are you using for your system? I'm currently using a pair of Genelec 1031As. But I want to trade them out for a pair of Neumann KH120s. But for 11 speakers my budget would be more in line with some Presonus E5s.
Justice C. Bigler
Old 04-11-2021, 05:35 AM
paulo m's Avatar
paulo m paulo m is offline
Are you using a receiver? Can you detail a bit on how you´re monitoring Tidal from your computer DAW on your setup? Thanks
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
Old 04-11-2021, 07:46 AM
reichman's Avatar
I think it is possible to buy DAMS without hardware, but I don't have experience building those systems. The only DAMS systems I've used were fully Dolby-certified. My strong recommendation is to not worry about DAMS until you hit a wall with DAPS. I know lots of people who own powerful Macs and do everything on one machine with DAPS. That's my approach right now as well. I spent a lot of time on a ladder, drilling lag bolts into my ceiling and upgraded my JBL LSR4300 series 5.1 system to 7.1.4. It's a long-story, but well worth it.
Yep, I bought an Apple TV 4K, and a refurbished Marantz 7705 which is a receiver, but without amps. In consumer-speak, it's a preamp processor. It has (13) +4 analog XLR outputs. So I patched those outs into my audio interfaces on DB25 snakes. TIDAL runs on the Apple TV and decodes to 7.1.4 (or on the Marantz 7.2.4!) and then I can listen to music and watch movies in Atmos in the studio. I'm not going to mince words- it sounds amazing and is so much fun. Lots more info about all the topics in this thread in the Atmos Professional Facebook group. AFAIK, the completely digital consumer Atmos systems are very expensive. I gave up on trying that, hence my D/A/D routing.
Nathaniel Reichman
Old 04-11-2021, 08:58 AM
Philharmonic7 Philharmonic7 is offline
Anyone with any insight whether DAPS will be PC compatible at some point? I have a HP z840 workstation and was curious on how to implement DAPS in my computer without needing another dedicated computer.
HTML code is On
FS: Dolby Atmos Production Suite License LDS Buy & Sell 1 10-20-2020 02:37 PM
Dolby Atmos Production Suite on Westmere 5,1 Stevo499 Post - Surround - Video 1 06-05-2020 07:36 AM
Dolby Atmos Production Suite 3.02 download LDS Post - Surround - Video 3 08-20-2019 07:03 AM
Dolby Atmos Production Suite garnoil Post - Surround - Video 2 03-13-2019 08:34 AM
Dolby Atmos Production Suite subhuffer Post - Surround - Video 20 03-10-2019 06:40 AM
