Pro Tools freezes on "Building Edit (or) Mix Window" when opening sessions
Hey everybody,
I've spent the past few days trying to work past this issue to no avail, and I would greatly appreciate some help. I'm using a Mid 2010 (6,2) Macbook Pro (2.4 GHz Intel, 8 GB 1067 MHz DDR3 RAM) with Mountain Lion 10.8.5. Pro Tools 10.3.10. Mbox Pro 3 Firewire. Everything was working fine a few days ago, until suddenly I was unable to open any session or create a new session without it freezing at either an empty progress bar, "Building Mix Window", or "Building Edit Window". The rainbow wheel spins indefinitely. This happened when I disconnected my computer from my interface and went to work away from home using the Built-In Output. I've had this problem before, but solved it for quite some time by updating Pro Tools 10.3.2 to 10.3.10. Since this issue came up again, I have: Deleted my pro tools preferences, tried to open pro tools with no plugins, reset my pram, completely replaced my HDD with a SSD, installed a fresh operating system (still 10.8.5), re-installed pro-tools, tried older version of pro-tools, tested my ram, and just about anything else I've found on forums with no luck. I'm really not sure what else to try, and I'm all ears if anyone has a suggestion. It worked reliably for a long time and I don't know how this could come out of the blue. Let me know if there's any more information I can provide... Thanks so much, -Josh. |
Re: Pro Tools freezes on "Building Edit (or) Mix Window" when opening sessions
A couple thoughts you could try:
1) repair disk permissions on the system drive with Disk Utility, reboot and try to launch PT 2) hold down the N key during launch until the Playback engine opens - does PT launch, and are you able to select the preferred hardware (if not selected already)?
Thanks very much for the reply.
I've repaired disk permissions & rebooted many times. PT itself always launches fine, but then I'm never able to open a session. I've tried selecting all the different outputs, but nothing works. |
I found a very strange solution to my problem...
Apparently there is some issue with the graphics card in my model of Macbook Pro. The graphics card switches between two different modes, and I think this feature was stopping Pro Tools from building its interface. I went to System Preferences > Energy Saver > and unchecked "Automatic graphics switching". It has been working perfectly since. Thanks for answering Stig. |
Ok, I see. I've never even heard of that. Thanks for reporting back.
"Pro Tools quit unexpectedly" when opening (holding "n" no longer fixes it)[RESOLVED] | andrew24c | macOS | 4 | 07-23-2014 07:21 PM |
Pro Tools 11 - constantly get "your settings have changed" message opening sessions | kirkbross | Pro Tools 11 | 10 | 10-22-2013 07:36 PM |
PT load freezes at "build edit window" | georgeearth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-25-2011 10:54 AM |
PT 8 LE freezes on " building edit window" during launch | georgeearth | Tips & Tricks | 0 | 08-22-2011 04:20 PM |
Pro Tools Launch stalls at "build edit window" when ethernet cable is connected | CGD107 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-06-2010 09:47 AM |
